 Post subject: Is this a good donor for Head replacement ?
PostPosted: June 18th, 2016, 2:03
Is this a good donor for head replacement
File comment: Customer Drive
File comment: Donor
 Post subject: Re: Is this a good donor for Head replacement ?
PostPosted: June 18th, 2016, 3:14
It should be....
www.datasave.ro
PostPosted: June 18th, 2016, 5:02
For me ... YES
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: June 18th, 2016, 5:17
what about the date ?!
there is chance it not matching ..
better to be same year
goodluck
PostPosted: June 18th, 2016, 9:44
Should be suitable, Toshiba aren't too fussy :-)
PostPosted: June 19th, 2016, 7:22
Close enough. Would definitely go for it.
PostPosted: June 19th, 2016, 13:31
have this heads did the work ?
lets know my friend ..
PostPosted: June 20th, 2016, 8:29
Find this
https://www.donordrives.com/blog/matching-guide#toshiba
PostPosted: June 20th, 2016, 13:47
yes very close
http://www.hpwlab.com
PostPosted: June 21st, 2016, 3:31
Drives look compatible. But i would have chosen the Sata variant MQ01ABD100 which is also compatible and will give you a Sata PCB to convert to.
Unless you have USB imaging tools like DDI USB add-on etc.
Web: https://www.day1data.de
PostPosted: June 21st, 2016, 3:44
YES YOU USED IT :D :D :D :D :D
Users browsing this forum: No registered users and 63 guests
