 Post subject: st5000 termial sending issue
PostPosted: June 20th, 2016, 11:30
5 Tb seagate . terminal ok i can recieve log . i can ctrl+ x . i can use some commands that read from drive like V40 V1 .but i can't use any commands to clear any thing
here is terminal output :-
Rst 0x80M
Spin Up
SpinOK
TCC:0025
Humidity:29.1%
(P) SATA Reset
Last Saved GlobalHeader EraseInProgress:00 DiscDataValid:00
NVC Power Loss Host Sig:478DDE7F PC:0112
NVC Debug Log: DEADBEEF 03 03 0000 00000000
PP: 6EEA1846 00000320 1D2A
TW: 1EF7D947 00000188 A735
GC: A06D4892 00000004 C0C1
ENP0x0113
New GlobalHeader EraseInProgress:00 DiscDataValid:00
NVCClearingEraseInProgress:00
NVCOkToWrite:07
NVCClientDisabled:00
DumpNVC
MCMainPOR: Start:
Media Cache Data Base 02468748B0
Check MCMT Version: Current
MC026: Reconstruction: MCMT Reconstruction Start
[RSRS] 759D
MC024: Reconstruction: Completed:
[MCMTWS] Tail/Head 5FDE 759D
SP200: MSP Restore Start
MSPBaseSegmentIndex 00005F67
MSPDiscSequenceNumber 000F811D
MC001: Reconstruction: EXCEPTION: Segment Read Failed
ReadFooters: TotalUserBlocks D840 Seg 5F67 Sequ 000F8159 MaxSeg 5F88 FirstFooterLBA 004E5D8A
ReadValidFooterOfMetadata: Footer LBA 00004E5D8C
Metadata Footer ID/Sequ AD59232C 000F8159.
Footer Obtained: FooterLBA 00004E5D8A
Seg Footer IDX 0000 SQ 000F8159 PL 0001 ID 2D44DDC5EF042A1B 2E5D4576E9CC4804 AD59232C
MC016: Reconstruction: EXCEPTION: Header is okay and valid Footer Present
ReadFooters: TotalUserBlocks D840 Seg 5F91 Sequ 000F815A MaxSeg 5FB2 FirstFooterLBA 004E7FFE
ReadValidFooterOfMetadata: Footer LBA 00004E8000
Metadata Footer ID/Sequ AD59232C 000F815A.
Footer Obtained: FooterLBA 00004E7FFE
Seg Footer IDX 0000 SQ 000F815A PL 0001 ID 2D44DDC5EF042A1B 2E5D4576E9CC4804 AD59232C
SP201: MSP Reading Band - 32FAD3A1 - 32FAEEA9
ProcessRWError -Read- at LBA 0032FAD3DB Sense Code=40000087
ProcessRWError -Read- at LBA 0032FAD4DA Sense Code=40000087
ProcessRWError -Read- at LBA 0032FAD4FB Sense Code=40000087
ProcessRWError -Read- at LBA 0032FAD530 Sense Code=40000087
ProcessRWError -Read- at LBA 0032FAD531 Sense Code=40000087
Update Mask - 0000000197D69D08 - 0000D840 - 01
Update Mask - 0000000197D6A988 - 00000001 - 00
Update Mask - 0000000197D6A989 - 00000001 - 00
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
 Post subject: Re: st5000 termial sending issue
PostPosted: June 20th, 2016, 13:54
Terminal commands locked I would imagine.
PostPosted: June 21st, 2016, 3:23
+1
If the P/N starts with 1ER or 1FK you can guarantee its terminal locked.
Can be bypassed easily with PC3K.
Web: https://www.day1data.de
PostPosted: June 21st, 2016, 4:43
I agree with terminal locked but i have the last version of pc3k and can't paypass with the new unlock options
do you have certain steps for this please?
Tawfeek Mokhtar
PostPosted: June 21st, 2016, 4:44
yes i think so ,, any clues here ? the new pc3k options can't unlock it
Tawfeek Mokhtar
PostPosted: June 21st, 2016, 5:31
Have you tried ACE Support? As you hava a legit pc3k.
http://www.rescue-it.se
PostPosted: June 21st, 2016, 5:43
just got replay now that " ST5000 drives have locked Techno Mode, and this problem can not be solved in current version "
I'm looking for out-box ideas . there must be some things to do :idea:
Tawfeek Mokhtar
