 Post subject: Any new informations for repair Bad internal ROM in WD PCB's
PostPosted: June 28th, 2016, 8:15
Any new informations, or methods, for WD internal ROM pcb like 701499, 701640, 701537?
Because i have a few PCb in bad internal rom, and sediv and wd marvel are not support repair BAD internal ROM, previous methods are not helpful, because drives are not locate in external rom, or not propertly initialize. Understand me?
 Post subject: Re: Any new informations for repair Bad internal ROM in WD P
PostPosted: June 28th, 2016, 8:52
Look at the answer from fzabkar (2nd message in this thread) and the links he provides:
http://hddoracle.com/viewtopic.php?f=3&t=1619
Does this help ?
PostPosted: June 28th, 2016, 9:07
No this theard is not helpful.
I want to know if are there any new information on the repairs of internal ROM.
PostPosted: June 28th, 2016, 10:26
This is too old my dear, here is a sample solution:
701499
Solder ROM chip on its place (prefer if you Program it with Programmer with its Match ROM i.e. Write Denali Family ROM)
Remove Both R13 & R6
701640
Solder ROM chip on its place, same steps as 701499
ADD 22k resister to R74
Connect and your done
hope this helps
Good luck :wink: and all the best
PostPosted: June 28th, 2016, 10:50
701499
Work, fine.
einstein9 wrote:
701640
Not work. and all methods not work, all checked.
PostPosted: June 29th, 2016, 7:34
pikus_09 wrote:
701499
Work, fine.
einstein9 wrote:
701640
for the 701640, Did you try Diff. types of ROM chip (SST, Winbond) ?
am refering to my old notes, its been long time really
PostPosted: June 29th, 2016, 16:48
well, checked in SST 25FL20, and Winbond 25X20
result is such :arrow: Wdek nor work(WD5000AVDS-63U7B0)
Ok, no problem.
Users browsing this forum: No registered users and 28 guests
