 Post subject: Formatting HDD in Disc Management progressing extremely slow
PostPosted: June 30th, 2016, 15:39
Trying to format the Seagate Backup Plus 4TB I just bought through Disc Management and it's been over seven hours with only 8% having advanced so far. The task manager shows the write speed as 12mb/s and I'm using a USB2 port. What can I possibly do at this point to minimize the chances of drive failure in case I want to stop the formatting process? The average time it took to complete on my other older 4TB Seagate drive was roughly the same time (seven hours), but this is excruciatingly slow, and I have no idea why that is. Any suggestions?
Thanks in advance.
 Post subject: Re: Formatting HDD in Disc Management progressing extremely
PostPosted: June 30th, 2016, 16:12
The fastest transfer rate via USB 2.0 is about 30MB/s. Typical speeds are more like 20MB/s. Your other drive was probably formatted via USB 3.0.
PostPosted: June 30th, 2016, 16:24
According to google math
(4 TB) / (12 (MB / second)) =
3.85802469 days
You want to speed it up, connect to USB 3 which is technically 10 times faster than USB 2.
PostPosted: June 30th, 2016, 17:23
So, if I were to use the offline option in Disk Management right now would it be problematic, say in terms of possibilities of drive malfunction?
PostPosted: July 1st, 2016, 7:39
Formatting means to logically define the physical space on the drive.
What gives the impression that the drive will sustain a failure/malfunction if you stop the formatting process?
Users browsing this forum: No registered users and 116 guests
