 Post subject: G Sense Error Rate
PostPosted: July 1st, 2016, 8:54
SMART data shows my g sense error rate is 80 and all other test results are look fine. Should i worry ?
ID# ATTRIBUTE_NAME FLAG VALUE WORST THRESH TYPE UPDATED WHEN_FAILED RAW_VALUE
1 Raw_Read_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
2 Throughput_Performance 0x0005 100 100 050 Pre-fail Offline - 0
3 Spin_Up_Time 0x0027 100 100 001 Pre-fail Always - 1052
4 Start_Stop_Count 0x0032 100 100 000 Old_age Always - 406
5 Reallocated_Sector_Ct 0x0033 100 100 050 Pre-fail Always - 0
7 Seek_Error_Rate 0x000b 100 100 050 Pre-fail Always - 0
8 Seek_Time_Performance 0x0005 100 100 050 Pre-fail Offline - 0
9 Power_On_Hours 0x0032 099 099 000 Old_age Always - 537
10 Spin_Retry_Count 0x0033 108 100 030 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 000 Old_age Always - 406
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 80
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 2
193 Load_Cycle_Count 0x0032 100 100 000 Old_age Always - 1157
194 Temperature_Celsius 0x0022 100 100 000 Old_age Always - 38 (Min/Max 25/52)
196 Reallocated_Event_Count 0x0032 100 100 000 Old_age Always - 0
197 Current_Pending_Sector 0x0032 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0030 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x0032 200 200 000 Old_age Always - 0
220 Disk_Shift 0x0002 100 100 000 Old_age Always - 0
222 Loaded_Hours 0x0032 099 099 000 Old_age Always - 527
223 Load_Retry_Count 0x0032 100 100 000 Old_age Always - 0
224 Load_Friction 0x0022 100 100 000 Old_age Always - 0
226 Load-in_Time 0x0026 100 100 000 Old_age Always - 269
240 Head_Flying_Hours 0x0001 100 100 001 Pre-fail Offline - 0
 Post subject: Re: G Sense Error Rate
PostPosted: July 1st, 2016, 9:09
G-sense error rate S.M.A.R.T. parameter indicates the number of errors caused by externally-induced shock or vibration.
Is it an external drive? Or is the drive exposed to constant vibration of some sort in the environment it is located in?
PostPosted: July 1st, 2016, 9:17
Its an internal drive. I usually use my laptop by placing it on a table. But last week i had to burn a disc and which showed me that my disc drive is not working properly ( so it vibrated a lot ). Will it be the problem ?
PostPosted: July 1st, 2016, 14:37
Probably not, but should make backup just in case.
Users browsing this forum: No registered users and 207 guests
