 Post subject: WD External Drive
PostPosted: July 13th, 2016, 2:23
I hope you are doing great.
What would be the best way to communicate this drive with PC3000.
This drive has a embedded USB connection to the drive and it does not have a SATA connection or any other, but, it has a connection of 12 pins in one side and 2 in other.
Connected through USB gives IO errors.
Attached picture of connections.
Thank you for the help.
Best regards,
 Post subject: Re: WD External Drive
PostPosted: July 13th, 2016, 2:25
Discussed in lengthy detail on the Acelabs forum...
PostPosted: July 13th, 2016, 3:22
You can replace the PCB to sata or use WDC Marvell USB/COM
have you replaced the HSA already ?
PostPosted: July 15th, 2016, 3:38
No, I have not replaced HSA.
AceLabs recommended me to connect a SATA connector as the drive is USB 3.0
