 Post subject: SATA Drive with Deleted Info
PostPosted: July 15th, 2016, 17:40
I hope you are doing great.
I have a SATA HDD with deleted info by a software customer used.
I used PC3000 to do a partition analysis and show deleted objects and it is not showing the deleted info.
Any suggestion?
I was advised to used R-Studio, but i do not have it available yet so I wanted to know if there is anything I can do with PC3000 before trying R-Studio.
Thank you for the help.
Best regards,
 Post subject: Re: SATA Drive with Deleted Info
PostPosted: July 15th, 2016, 17:42
What file system is it?
You can also use the R-Studio demo version to see if you can recover the files before buying.
PostPosted: July 15th, 2016, 17:51
You can use PhotoRec freeware to search for specific file types.
PostPosted: July 20th, 2016, 14:54
It is a ".gsm" it was a recording.
I saw the messages too late as I was in a hurry and I bought the R-Studio expecting I am going to use it in the future for RAIDs and others needs.
It was not available, well I found something like the file but it was 0 KB, so, looks like i just found the location where it was.
Thank you for your time.
Best regards,
PostPosted: July 20th, 2016, 16:06
If you have a good GSM file, or if you can create one, then examine its header for a signature. Then search for this signature on your drive.
