 Post subject: Lost Toshiba ROM ??
PostPosted: July 25th, 2016, 14:52
I have MQ01UBB200 with G3448A PCB and I desoldered the ROM to transfer it to a compatible SATA PCB, but unfortunately I Lost the ROM :cry: :roll: :cry:
is there a way around it ? please help
 Post subject: Re: Lost Toshiba ROM ??
PostPosted: July 25th, 2016, 15:01
No, sorry
The only way: find it
PostPosted: July 25th, 2016, 15:02
No. Its irrecoverable
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: July 25th, 2016, 15:06
How about if I found Hdd with exact model, fw, pcb.........?
PostPosted: July 25th, 2016, 15:10
There is a chance that I can recover data from your drive with lost ROM, but price is around $5K.
PostPosted: July 25th, 2016, 15:12
No chance even with 10k
PostPosted: July 25th, 2016, 15:47
It will not help, since all the CP's (except G-List, password, SMART and a few other non-critical modules) are stored in the chip you have lost
PostPosted: July 25th, 2016, 16:02
I don't think that P-List it's a non-critical module ;)
PostPosted: July 26th, 2016, 1:59
Spildit wrote:
Furthermore, when contacted about the matter of ROM regeneration, AceLab replied that it would be extremely difficult because :
- It is very difficult to access the surface without the original ROM on modern drives.
- The surface doesn't have a copy of 92 CP (CO).
Curiously, Spildit's own MK8025GAS drive produces this when HRT retrieves CP146:
00000000  43 4F 98 FB 40 FC B4 FB 20 FC 00 00 00 00 00 C1  CO˜û@ü´û ü.....Á
000001F0  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
... and this when CO is carved out of the ROM:
00000000  43 4F 98 FB 40 FC B4 FB 20 FC FF FF FF FF FF BF  CO˜û@ü´û üÿÿÿÿÿ¿
The ROM version has an XOR8 sum of 0x00 whereas the other version (from SA?) has an XOR8 sum of 0x81.
