Post new topic Reply to topic  [ 46 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: 0xC801 = DCO_FREEZE_LOCK_IN_PLACE - SA Format not comple
PostPosted: July 24th, 2016, 14:51
Loooool. Ehh, servo error's in scan D1, and limits full. Still I am not sure whether the script is , however, servo . Log attach tomorrow.
PostPosted: July 24th, 2016, 16:37
Case Closed, Unlock Sa solved problem DCO.
PostPosted: July 24th, 2016, 16:47
Can you show us the contents of module 02 before and after unlocking?
PostPosted: July 24th, 2016, 17:03
Yes, And there are some differences, and not just one byte.
File comment: 02 Before Unlocking
02.rar [903 Bytes]
Downloaded 1014 times
File comment: 02 After unlocking.
0002.rar [870 Bytes]
Downloaded 1132 times
PostPosted: July 25th, 2016, 1:36
Hi
There are many many types of locking in wd 02 modules. Sed lock. Sector read and write disable (for dvr hdd). Dco lock. Etc
Yes will upload picture of 02 after and before for sed locked drives. For dco unlock i think pukius upload 02 module.
Every wd family have different location of byte which we need to change for unlock. But the design and structure is same. Only location of byte goes on high offset and some time low offset.
Waqas Ali
PostPosted: July 25th, 2016, 7:01
Well, I preferred to attach the module unlocks the original before and after unlocking.
ok thanks for suggestion.
PostPosted: July 25th, 2016, 18:59
Aside from the model and serial number sections, I found the following differences:
section 3 - Feature Control
000000F0                 00 01 A4 02 00 00 00 00 07 7F 00       ..¤........
00000100  00 06 F4 01 01 00 01 00 02 9A 05 64 80 00 00 00  ..ô......š.d€...
00000110  20 0A 14 00 00 00 14 00 00 00 00 00 00 00 00 00   ...............
00000120  0A A0 0F 00 00 00 BC 34 00 00 00 00 10 01 00 02  . ....¼4........
00000130  1E 1E 00 00 00 00 00 00 00 00 00 00 00 00 01 01  ................
00000140  AC 0D 00                                         ¬..
000000F0                 00 01 A4 10 00 00 00 00 07 7F 00       ..¤........
section 13 - Background Configuration
00000300        00 01 E0 01 0F 0F 01 02 02 0A 01 01 00 02    ..à...........
00000310  02 04 01 00 FF FF 05 00 00 01 00 00 00 00 00 40  ....ÿÿ.........@
00000320  0B 02 00 E8 03 64 00 FF FF 10 00 00 00 00 01 0A  ...è.d.ÿÿ.......
00000330  40 42 0F 00 E0 C8 10 00 00 00 00 00              @B..àÈ......
00000310  02 04 01 00 FF FF 05 00 00 01 00 0A 00 00 00 40  ....ÿÿ.........@
00000320  0B 02 00 E8 03 64 00 FF 00 10 00 00 00 00 01 0A  ...è.d.ÿ........
section 14 - CDD Configuration
00000330                                      00 01 00 00              ....
00000340  00 00 05 00 00 00 00 00 FF FF 00 00 00 00 12 0A  ........ÿÿ......
00000350  12 00 00 00 05 00 00 00 00 00 1E 00 00 00 00 00  ................
00000360  00 00 00 00 4D 00 24 00 07 00 12 2E 00 00 00 0E  ....M.$.........
00000370  00 01 00 00 05                                   .....
00000360  00 00 00 00 4D 00 24 00 07 00 12 2E 00 01 00 0E  ....M.$.........
00000370  00 01 00 00 05                         ^^        .....
section 27 - ??? ("slow fix" section)
00000560                                         00 01 02               ...
00000570  02 00 32 00 00 80 0C 00 00 00 00 32 00 00 00 64  ..2..€.....2...d
00000580  00 00 00 1E 00 00 00 05 D6 06 00 4B 00 00 19 00  ........Ö..K....
00000590  00 00 01 01 08 01 00 00 00 00 40 00 02 40 00 10  ..........@..@..
000005A0  04 00 40 01 00 01                                ..@...
00000560                                         00 00 00               ...
00000570  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000580  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
00000590  00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00  ................
000005A0  00 00 00 00 00 00                                ......
PostPosted: July 25th, 2016, 19:20
Yes, because 02 before unlock is in oryginal backup SA,
no changed, but After unlocking 02 preparation for ARCO, slow fix and test B2
PostPosted: July 29th, 2016, 7:18
Hi
Here is the modules for SED lock and unlock for Firebird hdd,
Editing will make data recovery impossible , because it change the reading method of a sector.
must save the original 02 module if you need data, or after edit 02 for drives repair, convert the 02 editing to original position.
SED LOCK.rar [2.11 KiB]
Downloaded 1059 times
Waqas Ali
PostPosted: July 29th, 2016, 8:16
Ok, Thanks for suggestion.
But Self test, Test 1003 - shows error 7000 Servo PTM_code Base 704F, then self test stops, and not continue, checked in 10 scripts, but problem the same.
PostPosted: July 29th, 2016, 9:53
Hi
Remote ammy admin id please, PM me remote ID
PostPosted: July 29th, 2016, 15:37
It appears that section 31 is not the relevant section. Instead it is section 32.
SED locked
00000710  00 00 00 00 00 00 00 00 D6 06 00 1E 00 00 00 00
00000720  00 00 00 00 00 01 00 01 00 00 00 00 00 00 00 00
00000730  01 00 09 0F 0F 0F 0F 0F 00 00 00 00 00 00 00 00
SED unlocked
00000720  00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00
The relevant section of Mod 02 is section 32, not section 31.
000000A0  43 00 59 06 11 00 6A 06 1C 00 86 06 99 00 1F 07
000000B0  07 00 81 02 43 00 26 07 09 00 2F 07 69 00 98 07
Section 32, offset 0x71F, size 0x7 bytes
00000710                                               00                 .
PostPosted: July 29th, 2016, 17:28
Hi fzabkar.
I didn't understand what you want to say.
You need to change only one byte from 01 to 00 to unlock.
I not understand you means by section 31 or 32 and 7 bytes.
Waqas ali
PostPosted: July 29th, 2016, 17:32
Waqas ali, you need to understand the structure of Mod 02. Then all will be clear. It makes no sense to refer to absolute addresses within the module.
Analysis of Western Digital ROYL firmware MOD 02:
http://www.hddoracle.com/viewtopic.php? ... 821&p=3191
PostPosted: July 30th, 2016, 7:33
Hi friends Calmly I checked wd Black and probably has damaged the second servo . Heads 0, 2 , 3, 7 in the user area sequences have bad sectors and which may be interesting for this test does not pass the calibration selftest. Understand me?
PostPosted: July 30th, 2016, 8:26
well no one have time to learn in deep, only the address is good for every one, just change and do a work, thats it.
What is in back ground of 02 and structure of 02 module is a work or researcher or software developer.
normal person don't need this thing. he just need to do as quick as possible.
But in real your theory about 02 is 100% real and perfect. :beer:
Waqas Ali
http://Www.sediv.net
http://www.datamagicme.com
PostPosted: July 30th, 2016, 15:56
@waqas_ali766, Firstly, let me say that I am grateful for your information. It was very enlightening. However, your initial post was confusing and misleading for several reasons.
Firstly you stated that one needed to change the following data set from ...
    01 D6 06 00 1E 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 01 00 01 00 09 0F 0F 0F 0F 0F 00 00 00 00 00 00 00 00
... to ...
In fact the two data sets are identical.
Then you stated that "you need to change just one byte from 01 to 00 at offset 725". Clearly there are several instances of 0x01 in the data set, so it is not clear which byte must be changed.
Furthermore, your reference to offset 0x725 does not clarify your instructions. Worse still, the Hubble_LT resource which I downloaded from HDD Guru differs from your own, so this means there is no consistency even within the same family.
00000790  00 00 00 00 00 00 00 00 00 00 D6 06 00 1E 00 00
000007A0  00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00
000007B0  00 00 01 00 09 0F 0F 0F 0F 0F 00 00 00 00 00 00
The only consistent fact appears to be that the SED unlock byte is located at offset 0x06 within section 32.
Here are the relevant data for section 32 in the index:
000000A0  45 00 DC 06 10 00 EC 06 1C 00 08 07 99 00 A1 07
000000B0  07 00 B6 02 45 00 A8 07 09 00 B1 07 69 00 1A 08
As you can see, section 32 has a size of 7 bytes and is located at offset 0x7A1.
If we apply similar logic to pikus_09's 02 module, we find that his section 32 is located at offset 0x611.
00000610     00 00 00 00 00 00 00
Furthermore, the surrounding data differ significantly from your example.
00000600  00 00 05 0A 0C 00 00 00 FD FF 00 00 FF FF 00 00
00000610  01 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00
00000620  00 00 01 00 09 0F 0F 0F 0F 0F 00 00 00 00 00 00
PostPosted: July 30th, 2016, 16:39
Here is a locked example:
C:\mod2dump C:\WD10JMVW-11AJGS2\0002.rpm 32
ROYL header found
Module 02 consists of 47 sections
Section 32     Length 7 bytes
Addr  00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
0000  00 00 00 00 00 00 01                             .......
PostPosted: July 30th, 2016, 17:07
Demm, nice suggestion. But at this time I don't know what is, because Sediv software for me locked. I can't run execute SA calibrator, or selftest. Nothing was change. Always Reset impermentiale and nothing. :|
PostPosted: July 31st, 2016, 4:56
Hi fzabkar
i told in my previous post that the location of SED locked Byte vary on different families.
on Hubble_LT SED locked drive offset is 725, but in non-SED drives you will not find this byte and this sections of SED lock.
May be you download non-SED drive 02 from internet that why you get confuse.
Also some DVR drives which yous Port locked, also unlock by 02 module, but the offset which you need to change is at different location.
Some drives SPECIALLY denali become read only, you cannot edit any module of any other thing, this also because of 02 lock.
And in Pikuis case its Mantis Drives, Mantis and some more families have Issue, Hdd cannot Start format SA, and shows DCO freeze lock, this also because of 02 and some thing in ROM.
There is many many secrete in WD 02 module.
also the latest drive may change the user data by editing 02 module. same like Seagate SID drives, in Seagate SID drive if you use Z0,0,22 then the Seacos encrypted sector will be removed, and you get permanent access to terminal. now you can recover the data, once you edit any of user data sector then you will loss all user data.
Because after editing the sector , hdd write it by encryption, and when you read all byte of same sector goes in to garbage shape, because the decryption key is erased. (Seacos SID key) , the Key is always written on the HDD sticker, some one have to make a software to clone all sector of drive using the SID key, if the data goes garbage.
After that you cannot use this hdd in pc, because the hdd have encryption sector and not have decryption sector.
then you have to LOAD LOADER with winfof to update the firmware, also you can use Seagate firmware update.
after firmware update, like in my case hdd have FW=0003LVM3 anf after Loader write with Winfof the firmware version become 3LVM1
i attached my loader you can download
0003LVM1.zip [598.47 KiB]
Downloaded 1193 times
Its not easy to work with Latest drives, they are making it more and more complex.
Picture of Seagate SID self encrypted drive
you can see the SID key
Will upload the picture of Data sector soon, what happened if we remove the Seacos Security sector and AT overlay.
as written in the F3 commands document
Erase Seacos Data And Code (Level T 'Z')
0 - Minimal erase level
"0" to erase serial flash and reboot to mask ROM code Not supported yet
"1" to erase Appcode Not supported yet
"2" to erase Cert Not supported yet
"3" to erase Cert Table Not supported yet
"4" to erase AT Overlays
"5" to erase Congen Not supported yet
"6" to erase Security
"7" to erase Seasos
Type: Unsigned 8-bit value
Range: 0 to 0xFF
Default: None
1 - Erase mode
This parameter specifies the following options:
"1" means to erase the level the first param specify.
"0" means to erase from 7th level to the minimal level the first param specify.
Range: 0 to 0xFF
Default: None
2 - Valid Command Key.
this parameter must be equal to 22 Hex. If this parameter is not equal to 22 Hex,
the command will not be executed.
Range: 0 to 0xFF
Default: None
Output Data:
If an error occurred, the following information will be displayed.
"DiagError aaaaaaaa "
where
aaaaaaaa is the Diagnostic Error Code
If no error occurred, one of the following messages will be output to indicate the
status of the Seacos operation performed.
"Resetting"
"Erased Seacos"
"Erased Security"
"ConGen, not supported"
"Cert, not supported"
"Cert Table, not supported"
"Erased AT Overlays"
"AppCode, not supported"
"SFlash, not supported"
"Invalid level"
"Request dummy file failed"
"Open SIM file failed"
"Write SIM file failed"
"Erase Overlay failed"
Waqas Ali
www.sediv.net
www.datamagicme.com
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 160 guests
