 Post subject: Repair firmware seagate 320Gb hard drive
PostPosted: July 22nd, 2016, 6:39
Banned User
Hello friends
I have a 320GB hard drive seagate ST320DM000
Faulty Firmware
need help
I am from cuudulieuocung.org and I am currently banned from this forum for creating multiple accounts to promote my crappy website.
 Post subject: Re: Repair firmware seagate 320Gb hard drive
PostPosted: July 26th, 2016, 9:44
Banned User
What is your status? how you know that is faulty firmware?
https://t.me/pump_upp
PostPosted: July 26th, 2016, 12:52
Banned User
I have successfully data recovery
thank you
PostPosted: July 26th, 2016, 17:28
Banned User
thank you
wow good
Banned for spamming
PostPosted: July 26th, 2016, 18:32
The drive's current firmware package version (PH0G2D.CCD4.JQ019Y.CC49) is consistent with Seagate's official CC49 Pharaoh update:
http://www.users.on.net/~fzabkar/HDD/PH-CC49.TXT
#PHARAOH 2 HEAD
ST332041?AS;PH0G2D.CCD3.AA????.CC3?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD3.BZ????.CC3?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD3.CL????.CC3?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD3.CN????.CC3?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD3.CT????.CC3?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD3.FV????.CC3?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.AA????.CC4?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.BZ????.CC4?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.CL????.CC4?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.CN????.CC4?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.CR????.CC4?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.CT????.CC4?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.DP????.CC4?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.EB????.CC4?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD4.GZ0?9Y.CC??.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD6.CR????.CC6?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD7.BZ????.CC7?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
ST332041?AS;PH0G2D.CCD7.DQ????.CC7?.D2??;PHCC492H.LOD;PH0G2D.CCD4.JQ019Y.CC49.D289
Therefore it appears that the user has applied the retail CC49 update to OEM KC45 firmware. I'm not sure whether that was wise.
At present the drive is reporting a reduced capacity of 578258352 sectors which corresponds to 296GB (= 276GiB). This would suggest that a HPA is in force. If so, then tools such as HDAT2, MHDD or SeaTools should be able to remove the HPA and restore the drive's full capacity.
Users browsing this forum: Google [Bot] and 77 guests
