 Post subject: Swap PCB.
PostPosted: July 29th, 2016, 0:06
hi there, I'm going to swap this HDD (HTS545025B9A300) PCB on other similar but I don't know what is this integrated circuit? ( http://allegro.pl/ss0058-hitachi-hts545032b9a300-uklad-s93l-76ad-i5100998242.html) Is it a rom or ADC?. I don't find datasheet it is very useful.
Thanks in advance.
 Post subject: Re: Swap PCB.
PostPosted: July 29th, 2016, 2:50
Why are you going to swap the PCB?
PostPosted: July 29th, 2016, 3:32
The chip is an "NVRAM".
S-93L76A, Seiko Instruments, Low Voltage Operation CMOS Serial E2PROM, 512-word x 16-bit:
http://datasheet.sii-ic.com/en/serial_e ... L76A_E.pdf
http://pdf.datasheetarchive.com/datashe ... -41528.pdf
PostPosted: July 29th, 2016, 20:43
The chip is an "NVRAM".S-93L76A, Seiko Instruments, Low Voltage Operation CMOS Serial E2PROM, 512-word x 16-bit:
Thanks my friend.
I have two HDD Hitachi same models, but one the PCB is in short and the other is fine, so I have to interchange PCB. But PCB has two ROM (S-93L76A, Seiko Instruments Low Voltage Operation CMOS Serial E2PROM, 512-word x 16-bit, LE25FU106B CMOS IC 1M-bit (128K Serial Flash Memory)).
So my question is Have I to interchange both ROMs or both ROMs + uM?
Thanks in advance.
PostPosted: July 29th, 2016, 22:48
Did you check the fuse and the TVS diode?
PostPosted: July 29th, 2016, 23:34
See viewtopic.php?f=1&t=22287
PostPosted: July 30th, 2016, 5:23
That's the first thing to do.
Then you can try a PCB swap. The NVRAM chip MUST be changed, but the ROM chip might not need to be changed if it's the same version as the donor. Usually if the first two lines on the little white sticker on the PCB match, then the version should be the same.
Try with the NVRAM alone first, and see if the drive spins up. If it doesn't spin then the NVRAM and ROM aren't compatible so you'll need to switch the ROM too.
Be VERY careful not to damage or mixup the chips, especially the NVRAM (I suggest marking them somehow).
Users browsing this forum: Hohgua and 209 guests
