 Post subject: SEAGATE ST1000DM000 11 BEEPS THEN STOP
PostPosted: August 11th, 2016, 9:15
SEAGATE ST1000DM000 CC92
11 BEEPS THEN STOP
any idea?
Rst 0x20M
Servo Processor Is Reset.
RW: Disc Ctlr Initialization Completed.
ExecuteSpinRequest
FAIL Op=0100 Resp=0007
FAIL Op=0100 Resp=0003
No HOST FIS-ReadyStatusFlags 2002B001
ASCII Diag mode
F3 T>m0,6,3,,,,,22
DiagError 0000500E Process Defect List Error
R/W Sense 00000002, R/W Error 841C0087, List Offset 00000000, List Index 0000007
8, File Error 000000D0
F3 T>m0,2,2,,,,,22
 Post subject: Re: SEAGATE ST1000DM000 11 BEEPS THEN STOP
PostPosted: August 11th, 2016, 9:26
First off, stop powering on the drive. Second, if the drive is clicking then a translator regeneration (what you did in terminal) is pointless and never going to help.
The drive has failed read/write heads. That "FAIL OP" message you keep seeing means that it's unable to track the servo.
A clicking Seagate is bad heads 99 out of 100 times.
PostPosted: August 11th, 2016, 16:16
Plus one.
PostPosted: August 11th, 2016, 16:22
Absolutely correct.
The "one size fits all" DIY fix won't fix this one :-(
Requires parts, cleanroom, tools and most importantly experience and skills.
PostPosted: August 11th, 2016, 16:33
u will be lucky if not platter sucratch ..
hope not
Users browsing this forum: Majestic-12 [Bot] and 257 guests
