 Post subject: Seagate hdd repair F3T terminal command
PostPosted: May 20th, 2016, 17:51
Banned User
Hello all international friends
Today I will share with you the basic commands used for terminal F3T:
Command rebuilt slip list(V1) m0,2,1,,,,,22
Command rebuilt g list(V2) m0,2,2,,,,,22
Command rebuilt P list(V3) m0,2,3,,,,,22
Command zero fill with slip list m0,5,1,10,3,,,22
Command zero fill with G list m0,5,2,10,3,,,22
Command zero fill with P list m0,5,3,10,3,,,22
Command format with slip list m0,8,1,10,3,,,22
Command format with G list m0,8,2,10,3,,,22
Command format with P list m0,8,3,10,3,,,22
Command repair bad sector by Slip list m0,D,1,,,,,22
Command repair bad sector by G list m0,D,2,,,,,22
Command repair bad sector by P list m0,D,3,,,,,22
Command format (seacos XF ) by Slip list m0,20,1,,,,,22
Command format(seacos XF) by G list m0,20,2,,,,,22
Command format (seacos XF) by P list (most power full to repair bad sector and red and green blocks)
m0,20,3,,,,,22
Comman for erasing of all sector m0,5,1,,,,,22
Comman for formatting hard disk sectors m0,8,2,,,,,22
NOTE : Yes some of the listed commands will ERASE ALL THE USER DATA
Banned for spamming
 Post subject: Re: Seagate hdd repair F3T terminal command
PostPosted: August 14th, 2016, 13:29
Thank you
