 Post subject: External HDD mounted in Linux but Can't display any data.
PostPosted: August 15th, 2016, 2:53
Hello.
I have an External HDD with 1TB capacity and 500GB of this space used. When I Plug it to my system the External HDD mounted but Can't Display anything. I tested it on Both Linux and Windows and got same problem. How can I extract my data from it?
Thank you.
 Post subject: Re: External HDD mounted in Linux but Can't display any data
PostPosted: August 16th, 2016, 9:03
You likely won't be able to. But let's get more info first..
What is the full model drive? And how do you think it failed? Anything out of the norm happened?
PostPosted: August 16th, 2016, 11:02
The Model is "BUFFALO INC. (formerly MelCo., Inc.)" and when I plug it to Linux then it just show me an empty Hard drive but In Windows it ask me for format it. I did some Linux commands like "fsck" and "ntfsfix" but they told me that I must run "chkdsk" and after it Linux can show my Files but Windows can't. I want to know how can I understand that it is a software problem or hardware problem?
Thank you.
PostPosted: August 16th, 2016, 11:52
Thank you.
what is the s.m.a.r.t status ?
Data Recovery Pakistan
PostPosted: August 16th, 2016, 11:56
Thank you.
I would try running ddrescue to clone the drive to another one. If it can image all the sectors, then you know the hardware is good and can test things off the copy. Here's a tutorial about how to use ddrescue: https://www.data-medics.com/forum/how-t ... -t133.html
PostPosted: August 16th, 2016, 20:18
To test with limited free resources, I would try MHDD (http://hddguru.com/software/2005.10.02-MHDD/)
PostPosted: August 17th, 2016, 1:25
How about Linux Tools?
PostPosted: August 17th, 2016, 8:36
ddrescue is a Linux tool. Try MHDD (Dos). It will not try mount the drive or anything as it is a diagnosis based tool.
PostPosted: August 17th, 2016, 8:47
Is ddrescue vs dd?
PostPosted: August 17th, 2016, 8:49
ddrescue allows for more flexibility with more switches/options, including the most critical - ability to skip "bad areas".
Try both on practice drives and see for yourself.
Users browsing this forum: No registered users and 127 guests
