 Post subject: TOSHIBA DT01ACA300 - 3TB - dead? clicking
PostPosted: August 16th, 2016, 17:42
I need some help to recover data from my platters. I was wondering if I bought another HDD and moved one platter at a time to copy the data would that work or does each platter have a bit of data of the file? I hope someone could help me retrieve my data.
So i needed to ask some experienced users as clearly have no idea what i'm doing. So I have this Toshiba drive which has only films on it. All my videos, home videos, downloaded ones. All is on this one drive. So I noticed that it was preforming really slowly and would freeze time to time. I noticed it maybe the drive so i took it out and mounted it on an enclosure which asked me to initialize the drive i then mounted it on a dock, this time it asked me to format. I decided not to I put it back in my computer and copied a few files before it kept crashing and eventually stopped working. I looked online to see how youtube could help. they said the PCB board could be changed i changed this and the drive started to spin again but didn't show up on the computer. They said that the head maybe on the platter therefore its not park and not reading. It wasn't and i put the cover back on. I don't know what to do now.
thank you in advance guys!
 Post subject: Re: TOSHIBA DT01ACA300 - 3TB - dead? clicking
PostPosted: August 16th, 2016, 22:26
If the data is valuable to you the only solution (if its not to late) is a data recovery pro NOT A COMPUTER TECH
and DO NOT open the lid anymore outside of a clean environment (class 100)
AND DON'T YOU DARE REMOVE THE PLATTERS
PostPosted: August 17th, 2016, 2:30
Banned User
if important data necessary, and need replace PLATTERS. see this article If important data necessary, and need replace PLATTERS. see this article http://www.cuudulieuocung.org/2016/06/c ... t-dia.html
But I think you should replace head
I am from cuudulieuocung.org and I am currently banned from this forum for creating multiple accounts to promote my crappy website.
PostPosted: August 17th, 2016, 4:38
I'm only hoping this thread is a joke.
PostPosted: August 17th, 2016, 11:17
Sadly, it's probably not :-(
PostPosted: August 17th, 2016, 12:25
I could help if you will send drive to me. PM me.
PostPosted: August 18th, 2016, 15:08
Banned User
Can you look for a hard disk drive compatible model to replace head
Users browsing this forum: No registered users and 49 guests
