 Post subject: Toshiba MQ01ABD100H, IDs, but no Data.
PostPosted: August 17th, 2016, 20:51
Hi all. I have this Toshiba MQ01ABD100H 1TB 2.5" laptop HDD that IDs nicely on PC3K,
does everything a drive should, except I get all RED squares in Data Extractor.
As well, on DDI, the drive IDs but no data can be read.
I have cleared the G-List as suggested with other Toshiba drives in this condition.
This is a newer model, on the market not even 3 years, and I'm not familiar with
what else could be wrong.
Any help appreciated.
 Post subject: Re: Toshiba MQ01ABD100H, IDs, but no Data.
PostPosted: August 17th, 2016, 22:12
tried reading through the utility?
PostPosted: August 18th, 2016, 1:26
MQ01ABD100H
That is hybrid drive (with NAND)
Guess where is the problem :roll:
99% it is giving you through the terminal :
SIGNATURE SCAN FAILED
P90 FATAL
HDD FATAL ERROR
Solution obviously not easy .
PM Me.
Angel Data Recovery
PostPosted: August 18th, 2016, 17:59
Hi, thanks for the reply.
I am not sure what you mean. Please elaborate, more details
and I will answer you.
Thanks.
PostPosted: August 18th, 2016, 18:27
Thanks.
Sec 6.9 in Toshiba PC3K manual
PostPosted: August 18th, 2016, 18:34
to DataPros: Could you explain what does it mean (it's from your site) - Motor replacement, Damaged Platter repair?
PostPosted: August 18th, 2016, 20:48
Does this equal spinrite?
PostPosted: August 19th, 2016, 8:34
lol, I see that should say recovery. Thanks.
PostPosted: August 19th, 2016, 8:36
Thanks.
Thanks for pointing that out!
I see the (new, June 15/16) manual for Toshiba has been VASTLY increased in content!
PostPosted: August 19th, 2016, 14:50
What about motor replacement? On which models you are replacing motor?
PostPosted: August 22nd, 2016, 8:04
We can fix these drives with NAND issues, but can you show terminal output during power up?
Mike
https://www.mjm.co.uk/
PostPosted: August 24th, 2016, 20:20
Mike
Hi Mike. No, there is NO terminal output during power-up.
But, the Terminal works because the Red light flashes while saving ROM via Terminal, for example.
And, anything you type is echoed in Terminal, after it prints a ">" character.
Users browsing this forum: Google [Bot] and 227 guests
