 Post subject: help! Rom recovery using tl866 programmer
PostPosted: August 28th, 2016, 8:57
i am trying to program rom using tl866 universal programmer
on wd drive pcb 771672-004
ic no: winbond 25X20ALNIG
please help me where i am making mistake. programmer not reading the ic
 Post subject: Re: help! Rom recovery using tl866 programmer
PostPosted: August 28th, 2016, 10:02
Have you tried to read it out of the circuit ?
PostPosted: August 28th, 2016, 10:17
Are you sure the socket or the clip are the right way ? My old eeprom burner informs a FF FF FF FF id when the chip is upside down.
PostPosted: August 28th, 2016, 10:52
The adapter is inserted the wrong way around. The "1" needs to be at top-left, although it looks like the red lead is connected to pin 1 of the reader so double-check that the red lead of the clip is connected to the red dot on the IC.
PostPosted: August 28th, 2016, 13:57
i insert the adapter as you told. but still getting same error
it is not reading it.
here is the situation please help
PostPosted: August 28th, 2016, 14:36
connection was wrong in the clip
but now i adjust it perfectly.
now this error encountering
PostPosted: August 28th, 2016, 15:51
earlier you wrote:
Why have you selected now W25X16AL ?
Select W25X20AL
remove the V from check device ID
then read it
PostPosted: August 28th, 2016, 16:37
jermy wrote:
Select W25X20AL
then read it
can you please tell me which adapter is suitable for seagate 2.5 hdd rom??
i dont want to sold ic i want adopter like that i am using now. this adapter is not working fine with seagate 2.5 hdd.
PostPosted: August 28th, 2016, 17:29
Now I have lost you
The ROM you are trying to read is from a WD.
So how did you get to Seagate ?
PostPosted: August 29th, 2016, 4:24
On your screenshot you have W25X16AL selected which is different to chip that you told us.
All you need to do is select the correct model and it should read fine.
By the way where did you get that clip device so you don't have to de-solder?
Web: https://www.day1data.de
PostPosted: August 29th, 2016, 7:15
jermy wrote:
Now I have lost you
this solution is solved thanks.
i was selecting the wrong chip model.
i also want to write rom in seagate 2.5 that is why i am asking. i dont want to sold the ic i want to do it directly.
this adapter isnt working on seagate 2.5 because ic is different.
i hope you got me now.
PostPosted: August 29th, 2016, 7:41
I think there is no clip in the market for that
Build your own clip
PostPosted: August 30th, 2016, 1:29
Banned User
Can you must work Reflash Firmware tl866
I am from cuudulieuocung.org and I am currently banned from this forum for creating multiple accounts to promote my crappy website.
PostPosted: August 30th, 2016, 7:19
Are you talking about the flat Winbond chips? They are almost on every 2.5" drive not just Seagate.
Can't see why you can't solder some BGA balls on the sides of the chip then use your clip device.
PostPosted: August 31st, 2016, 9:39
yes i am talking about flat winbond chips. do you have any picture how to solg BGA BALLS??
PostPosted: September 3rd, 2016, 6:17
now i am getting this error ic is detected but this is giving error on rom writing
any idea why it is happening ?
PostPosted: September 3rd, 2016, 6:23
LarrySabo,
bro any idea how to solve this issue??
PostPosted: September 3rd, 2016, 8:42
If I understand the screenshot correctly, it failed to write new content to the ROM? You could try it using a known-good/new ROM, to see if it is a bad IC. I had a lot of problems with read/write errors on mine so I bought a Revelprog IS unit instead. Besides, it handles low voltage ROMs whereas the TL866 doesn't. Have yet to have a problem with the Revelprog IS.
Also, I usually have to unsolder the IC from the PCB because other components in the circuit load down the programmer too much, causing bad reads. Is the ROM off the PCB when you try to write to it? Is the USB port used by the programmer on a hub? Use one directly connected to the PC motherboard, at the back of the PC.
Users browsing this forum: No registered users and 87 guests
