 Post subject: Maxtor STM
PostPosted: September 5th, 2016, 0:52
Hello all
This HDD get busy and no more clicking and any other head noise.
How can I access to resource?
Any jumper should set?
Phoenix Computer Forensic Laboratory
http://www.databack.ir
 Post subject: Re: Maxtor STM
PostPosted: September 5th, 2016, 2:54
Show terminal
PostPosted: September 5th, 2016, 2:59
MRT terminal
PostPosted: September 5th, 2016, 3:43
It's not an F3 drive.
PostPosted: September 5th, 2016, 3:46
Yes I know, but I can not find other way to access terminal with MRT!!!
What you suggest?
PostPosted: September 5th, 2016, 3:52
This is log with hyperterminal
PostPosted: September 5th, 2016, 4:36
Most likely its from the Maxtor Shasta family.
You need to put the drive into safe mode.
PC3K uses a special adapter for this (see picture).
So I'm not sure how you can do it in MRT
Web: https://www.day1data.de
PostPosted: September 5th, 2016, 4:57
Seagate U5
Reset
1024k x 16 DRAM
NHAWK - 1_Disk S-42 03-27-07_13:01
HM SFI
(P)SATA Reset
F>
PostPosted: September 5th, 2016, 9:37
YOU CONNECT WITH BAUDRATE 9600 AND GET TERMINAL
PostPosted: September 5th, 2016, 10:45
Log detail on top
PostPosted: September 5th, 2016, 11:46
databack, set baudrate 9600 and you got T/ not f3T
PostPosted: September 5th, 2016, 11:52
Can not load T level or else, only F level
PostPosted: September 6th, 2016, 1:16
Thanks Spildit
output log:
PostPosted: September 6th, 2016, 10:44
Solved!
This is a head problem and change it!
PostPosted: September 7th, 2016, 10:14
Thank you Spildit and have a nice day...
Users browsing this forum: No registered users and 37 guests
