 Post subject: Samsung 840EVO
PostPosted: March 10th, 2015, 9:20
I got this SSD, drive stays busy and can't get it into tech mode, can someone help me testing the components please, the issues to do a chip off recovery this drive is encrypted with truecrypt. I'm just started to learn SSD recovery.
Thank you in advance.
 Post subject: Re: Samsung 840EVO
PostPosted: March 10th, 2015, 10:02
Likely not an eletronics related issue. Seems more like firmware issue.
PostPosted: March 10th, 2015, 16:12
Agree, much more likely to be a FW problem.
Btw.... "truecrypt"??? :?
PostPosted: March 10th, 2015, 23:29
well I guess better than "NoCrypt" even if TC is dead ;)
PostPosted: March 26th, 2015, 1:31
tried safe mode and a loader with SSD addon on PC3K?
PostPosted: September 5th, 2016, 17:42
How can I get into safe mode on a 840 EVO with 256 GB? It is the upper right PCB: http://www.hardwareluxx.de/media/jphoto ... 50x633.jpg
PostPosted: October 10th, 2016, 12:48
I found the way to Safe-Mode: You have to short the 2 pins next to the JTAG pins. In Safe Mode, a UART interface in 2 other pins near them is available. More details can be found here: http://www2.futureware.at/~philipp/ssd/ ... Manual.pdf
