 Post subject: This is bad... right (failing hard drive?)
PostPosted: September 1st, 2016, 4:02
I have inspiron 7737 and diagnostic tools seem to say the hard drive is bad.
 Post subject: Re: This is bad... right (failing hard drive?)
PostPosted: September 10th, 2016, 16:12
Yes, began failing.
Do you need data from it?
PostPosted: September 11th, 2016, 1:05
Hi ,
Copy your Imp Data ,Erase This Drive Get A New One Install os and dump data back to that ,You can also go in for a 250/500 GB SSD or if money is not a issue 1TB SSD
