 Post subject: ERASE WAIT TIME
PostPosted: December 11th, 2005, 9:48
Is it possible change erase wait time for other value not 350ms ?
Thanks.
 Post subject:
PostPosted: December 11th, 2005, 10:28
I've often wondered that myself.
 Post subject:
PostPosted: December 11th, 2005, 16:21
did you try help command in mhdd?
help en scan, for example...
anyway it is possible (see mhdd.cfg)
 Post subject:
PostPosted: December 12th, 2005, 6:34
HI .. Maysoft...
this is what i see in Mhdd.cfg
#PRIMARY_ENABLED=TRUE
#AUTODETECT_ENABLED=TRUE
#DEVICE=3
Can you tell me what command must added to change erase wait time value..
 Post subject:
PostPosted: December 12th, 2005, 13:57
below the line 3 in the mhdd.cfg file you will find:
#SCAN_ERASEWAITSDELAY=350
you can change the time in msec with this line, also you can change the time out set with:
#SCAN_TIMEOUT=240
and in this case the time is in sec
 Post subject:
PostPosted: December 12th, 2005, 21:26
thanks
 Post subject:
PostPosted: December 17th, 2005, 13:39
How does "erase wait time" really works ?
I've run it and i got a few erased blocks. But when i push F8 , SMART reports reallocated sector = 0 [RAW VALUE] what means no sectors were reallocated on my disk. Where did erased blocks go ?
 Post subject:
PostPosted: December 17th, 2005, 16:02
It's just a magic…
 Post subject:
PostPosted: December 17th, 2005, 19:53
i'm serious...
 Post subject:
PostPosted: December 17th, 2005, 20:00
delays usually caused by "unstable" bits. that requires the drive to apply more ecc correction. By rewriting that sectors we also rewrite ECC fields, and blocks are good again…
On all modern drives if you see a bad block or a delay, that usually means not a physical bad but just ECC error.
 Post subject:
PostPosted: December 17th, 2005, 23:37
So is there a similar setting that can be added to the mhdd.cfg file to change the timeout while performing the ATOF command? Sometimes drives with lots of errors take a long time to copy to image files. It would be nice to tell MHDD to be less patient.
Is there a MHDD.CFG reference somewhere?
Thanks,
Phil
 Post subject:
PostPosted: December 18th, 2005, 0:08
This is impossible.
 Post subject:
PostPosted: December 18th, 2005, 0:18
I was afraid you were going to say that. :cry:
 Post subject:
PostPosted: December 18th, 2005, 0:47
sorry :oops:
 Post subject:
PostPosted: December 19th, 2005, 0:32
Site Admin
(please disregard this message)
Users browsing this forum: No registered users and 416 guests
cron
