 Post subject: Another Samsung HD322GJ Problem
PostPosted: September 11th, 2016, 3:53
i recovered app 10 HD322GJ that all of PCB faulty
it doesn't spin. And there is no visible error on PCB.
TVS's O.K.
What should I suspect part?
 Post subject: Re: Another Samsung HD322GJ Problem
PostPosted: September 11th, 2016, 12:19
Thanks for reply.
i desolder rom chip from faulty pcb as you can see...
i recovered disks via rom transfer. Disk spins normally.
i 've five HD322GJ that needs pcb for this common problem...
Maybe main chip or easy problem?
PostPosted: September 11th, 2016, 15:46
Measure the Vcore, Vio and Vneg voltages:
http://www.users.on.net/~fzabkar/HDD/HD103SJ_regs.jpg
PostPosted: June 18th, 2017, 7:55
thanx for reply.
i have 3 broken boards of hd322gj.
at diode mod
vio(up) vio (down) Vneg
A 0,646V 0,082V 0,180V
B 0,635V 0,068V 0.180V
C 0,685V 0,108V 0,190V
PostPosted: June 18th, 2017, 15:05
bad motor controllers
PostPosted: June 19th, 2017, 2:44
ok what are the expected value?
PostPosted: June 19th, 2017, 3:10
2.5v, 1.2v (?) and -5v
confirm 12v and 5v at diodes
PostPosted: June 20th, 2017, 13:30
Well,
Sometimes The Zero Ohm Resistor in Series From Main Supply is Open ,Please Check That Too ,Very Common In These PCB 's
PostPosted: June 28th, 2017, 9:58
he probably measured voltages without supply, in diode mode across the tvses, so it is not very meaningful
at diode mod
Users browsing this forum: No registered users and 85 guests
