 Post subject: MAXTOR HDD PCB Replacement!!!
PostPosted: September 13th, 2016, 20:12
I hope you are doing great.
I have this MAXTOR which had the PCB damaged and need help to make it work with the new HDD i got to get the new PCB.
Please find OLD HDD Info:
Model: 2B020H1
HDA: 11B
PCBA: 11A
UNIQUE: 11C
CODE: WAK21R90
NEW HDD Info:
Model: 2B020H1
HDA: 11A
PCBA: 05A
UNIQUE: 11A
CODE: WAH21PB0
Thank you for the help.
Best regards,
 Post subject: Re: MAXTOR HDD PCB Replacement!!!
PostPosted: September 13th, 2016, 21:00
You want to replace the PCB or HSA ?
If PCB, Maxtor doesn't unique adaptive on the PCB .
PostPosted: September 13th, 2016, 21:12
Thank you for the reply.
I want to replace PCB.
I just swapped the PCB but it is not working in PC3000.
It is giving an error that is not recognizing the HDD.
Thank you.
Best regards,
PostPosted: September 16th, 2016, 10:25
Attached pic
PostPosted: September 16th, 2016, 11:04
Hello olinyer, may a ask you a question? Why did you open the hdd? Did it make some noise? I assume that you are not connecting the hdd opened...I am right?
Best
F
Users browsing this forum: No registered users and 106 guests
