 Post subject: Differentiate of Serial Number on PCB and Disk
PostPosted: September 18th, 2016, 13:26
i have a st3500418as which i don't know where it comes.
terminal say that serial number :9VM2M159
but the label say that :9VM2M158
and
F3 T>
RW subfile error 2044
SIM Error 2044
No HOST FIS-ReadyStatusFlags 2002A1A5r28
Input_Command_Error
F3 T>m0,2,2,,,,,22
RW subfile error 201FMax Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level =
16, Max Certify Rewrite Retries = not supported
DiagError 0000500D
User Partition Format Failed - Elapsed Time 0 mins 00 secs
R/W Sense 00000002, R/W Error 843200A6, File Error 00000000
Blk Addr 000055AA55AA, Blk Addr Type AA, Cyl 55AA55AA, Hd AA
F3 T>r2b
DiagError 00000024
Maybe P-List has fault or PCB is different?
And i have a st500dm002.
i couldn't get F3 T> .
i think pcb's are mixed.
How can i know Pcb's serial number without terminal output message? or how can i know pcb's are get mixed.
 Post subject: Re: Differentiate of Serial Number on PCB and Disk
PostPosted: September 18th, 2016, 13:55
The serial number is in the ROM
PostPosted: September 18th, 2016, 15:15
Let's say that someone with a broken RAID 0 or 1 enclosure attempted to fix a bad drive with the PCB from the other ...
Or that someone aquired several drives at the same time (sequential serial number9 and later on attempted to fix the damaged one with a PCB swap ...
Looks like PCB is not native unless they changed serial number themselfs for whatever reason.
+1
I thought so, too.
novices try pcb swap without transfering rom. so then they leave
today i recovered two st3500410as with success. only i realise that serial number wrong.
@418as
i correct 1b file with seagate P-list editor but it's useless. ( i have backup)
i'm sure that pcb is not native.. my problem is PCB oriented.
this is waqas's video for SIM Error 2044.
https://www.youtube.com/watch?v=Pnb10I8dwLQ
PostPosted: September 19th, 2016, 10:03
F3 T>m0,2,2,,,,,22
Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 2DF8
DiagError 0000500D
R/W Sense 00000002, R/W Error 843200A2, File Error 00000000
Blk Addr 7B400001, Blk Addr Type D0, Cyl 00000000, Hd 01
Try and give result and you check that PCB is original go to T level and press = J that terminal show hard disk model number
Rst 0x10M
RW subfile error 205f
ASCII Diag mode
F3 T>m0,2,1,,,,,22
User Partition Format 4% complete, Zone 00, Pass 00, LBA 0002CB59, ErrCode 00000080, Elapsed Time 0 mins 30 secs
User Partition Format Successful - Elapsed Time 0 mins 30 secs
Zone re-format was skipped.
F3 T>
and my English is not correct
PostPosted: September 19th, 2016, 10:06
AFTER put J command in terminal T you see this msg
=0B) Firmware Key: FF FF FF FF FF FF FF FF FF FF FF FF FF FF
(P1=0C) Firmware Key Checksum: FFFF
(P1=0D) Date of Manufacture: 05282013
(P1=0E) Destroked Buf Size Index: 01
(P1=0F) Final Mfg Op: Invalid
(P1=10) Final Mfg Erc: Undefined
(P1=11) System Area Prep State: FE
(P1=12) SPT Auto Run Delay: 00
(P1=13) Reserved: 00
(P1=14) Checksum: FFFF
(P1=15) External Model Number: ST500DM002-1BD142 >>>>>>>>>> check model
(P1=16) Internal Model Number: ST500DM002-1BD142 >>>>>>>>>> and check
(P1=17) IDEMA Capacity: 3A386030
PostPosted: October 6th, 2016, 15:44
Thank you very much indeed. this helps to me.
But new model of seagate doesn't respond ctrl+Z or L command at alone of pcb.
How could we determine serial number of these new PCB alone?
PCB messing is possible..
Users browsing this forum: Google [Bot] and 232 guests
