 Post subject: Cloned drive not behaving the same as original
PostPosted: September 21st, 2016, 13:14
I have a Macbook for which I wanted to make a backup in case something ever happened to the drive.
I took the drive out of the macbook and made an exact clone of the drive using ddrescue to a brand new drive of the same size.
I tried putting the cloned drive into the macbook and it wouldn't recognise it. I hooked it up to a windows computer (which has software installed to read HFS+ volumes), and it said the volume was not allocated in Disk Management. When I connect the original drive it can see the partitions in Disk Management no problem.
When I scanned the drive using data recovery software, it picks up the partitions just fine so I know the clone worked.
Is there any reason why a perfect clone would behave differently in this situation? The original is a HGST and the new drive was a Western Digital, but both exact same number of LBAs. Could the fact they are different brands be causing an issue?
Cheers for any advice
 Post subject: Re: Cloned drive not behaving the same as original
PostPosted: September 21st, 2016, 13:18
Hi Taserx! You can try opening the first sector of both drives with an hex editor and check if they are exactly the same.
Best,
F.
PostPosted: September 21st, 2016, 13:23
Ok I'll give that a go. But ddrescue reported 0 errors so I don't understand how they could be different if they are.
PostPosted: September 21st, 2016, 13:44
Me neither :D , but i think it is a good way to start figuring it out.
Best!
F
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 60 guests
