 Post subject: Have someone work with this Hdd WDC WD10SPCX-08S8TT0
PostPosted: September 23rd, 2016, 14:31
Hi All ..
Have someone got this Hdd for recovery b4 ?!
i try to read 00c5 as my friend joy advice me to do first but i can >>
drive spinning ok sound normal ..
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
Read ROM................................ : Ok
ROM Data size........................... : 512 Kb
Flash ROM dir reading................... : Ok
Flash ROM dir reading (Ext)............. : Ok (Active)
Modules directory address............... : 205 550
SA Translator loading................... : Ok
ROM Modules:
ROM version............................. : 02.0TA
ROM F/W version......................... : 0002000T
Overlay F/W version..................... : 02.0TA
Servo F/W version....................... : AK.26
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
Service area:
Permanent overlay....................... : Not loaded
SA dir reading (ID)..................... : Ok
SA Access............................... : NONE
Configuration reading................... : No SA copy avalabled
if someone face and success with this Drive plz help
thanks
 Post subject: Re: Have someone work with this Hdd WDC WD10SPCX-08S8TT0
PostPosted: September 23rd, 2016, 15:42
Hi! Does the hdd have original PCB? Have you already tried to upload a loader?
Best!
F
H13 wrote:
Hi All ..
RAM:
ROM:
ROM Modules:
Service area:
thanks
PostPosted: September 23rd, 2016, 15:45
Best!
F
H13 wrote:
Hi All ..
RAM:
ROM:
ROM Modules:
Service area:
thanks
hi and thanks
it's not taken the family automatic .. i thinks pc3k is not support it yet ?!
any one can help ?
PostPosted: September 24th, 2016, 11:45
Hello Friends --
No body have this drive b4 ?
Users browsing this forum: Google [Bot], Hardcore Games and 240 guests
