 Post subject: WD Selfscan - how to enable
PostPosted: September 25th, 2016, 10:07
I am getting the following error on some drives (eg. Jamaica 4KV) and SS won't start:
BG_PST_DISABLED_VIA_DEBUGSTOP
error code: 3807
Can you help me? Which module to modify and how?
Thank you in advance.
Those who know don’t talk. Those who talk don’t know.
 Post subject: Re: WD Selfscan - how to enable
PostPosted: September 25th, 2016, 11:00
As I may have read somewhere that in order to do any self scan, modules should be fine and should read by id and aba both. Also drive parameters should load normally. If that is unchecked, then one could lead into problems.
Wrong do can cause HDD to go into ERR state on connection.
Rgds
PostPosted: September 25th, 2016, 11:25
Thanks, but modules are OK. Problem is that SS is locked. Some softwares can unlock it. Would like to know, how it is done manually.
PostPosted: September 25th, 2016, 16:12
Spildit wrote:
What software are you using ?
Buy SeDiv, WDMarvel or TREX AUTO.
:shock:
Are you paid a commission? :lol:
Let me clarify my question: How to modify the necessary module in a hex editor to ensure start of selfscan in drives where SS otherwise won't start?
PostPosted: September 25th, 2016, 16:28
I don't have an answer, but module 02 has the enable/disable flags for various features. Perhaps you could compare it against modules 802E and 802F?
PostPosted: September 26th, 2016, 5:06
helpless,
Try this. Only free tools need. Tested on some Zephyres.
Put the disc in the "not full initialized" mode by editing of addresses of regions of service area +1. Then download module 11 overlay, read 04 sectors of CONFIG_FILE in RAM by the demo WDMarvel in "Work with RAM". It is an essential module 02 to start of selfscan. Then return addresses of SA regions back. Save your 02 module, record obtained 02 in the service area and start selfscan. After selfscan end, return your saved 02 back.
PostPosted: September 26th, 2016, 17:32
So no changes in rom, ah?
PostPosted: September 26th, 2016, 18:31
What is the drive?
Spildit selftest and wdmarvel = problems.
PostPosted: September 27th, 2016, 5:22
pikus_09
Drive is WD2500BPVT-22JJ5T0 Jamaica 4KV
E123
Thanks for your suggestion, however I cannot write modified 02.mod back to system area.
error writing module ID02 - success
Original 02.mod can be written without problem. Maybe there is a check before writing and header is different and causes trouble?
Here are the first four sectors of CONFIG_FILE read from RAM:
02.rar [763 Bytes]
Downloaded 611 times
PostPosted: September 27th, 2016, 5:40
Spildit wrote:
...I do have full (paid) version fo WDMarvel and it can unlock SS on newer ROYL drives.
Well, you are in the position to compare firmware before and after unlock, that would be real help.
...you could compare it against modules 802E and 802F?
Those mods are basically empty.
PostPosted: September 27th, 2016, 5:54
It`s not a valid 02 module. Everything is done correctly, but part of the necessary data is abscent. Here is my method will not work. Can I look at your right 02 module?
PostPosted: September 27th, 2016, 5:58
Here is the original mod 02.
orig_02.rar [978 Bytes]
Downloaded 600 times
PostPosted: September 27th, 2016, 6:14
Try it, but I think it also will not work.
I do not see anything like the required mark.
02.mod.zip [930 Bytes]
Downloaded 607 times
PostPosted: September 27th, 2016, 6:42
I don't know what mark you were looking for, but selfscan started!
I shall compare these modules and try to find out the right procedure myself. Should I fail, I shall turn to you for explanation.
Thanks a lot! :cool:
PostPosted: September 27th, 2016, 6:52
- I have too little data to determine exactly which key is responsible for enabling the desired mode. There are only guesses. You have added a little bit of information to think about.
PostPosted: September 27th, 2016, 15:09
Spildit wrote:
It's not Mod 02 related .....
Changes are done even in ... ROM.
Fzabkar was right and wdmarvel use changes in rom only to get right flags in 02.
PostPosted: September 27th, 2016, 15:30
sorry i got it confused in 01 and 02....02 is id right?
rgds
PostPosted: September 27th, 2016, 15:36
So can we imply that if ID is lost, the SS won't run?
rgds
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 180 guests
