 Post subject: recover data
PostPosted: September 15th, 2016, 13:20
hi, im' trying to recover data from hd of 3tb, split in two partition (the smallest for backup the system and one for the data). windows seven is on a ssd. i use it to dw from emule so the pc run day and night. one day i wake up and the pc recognise only the partition with the backup.
chkdsk /f don't fix and returm me corrupt master file table
I have tried with various partition/data recovery softwares but only diskdigger show me files.
the real problems comes when diskdigger during saving some file crash, now the pc don't see anything.
what can i do now?????
 Post subject: Re: recover data
PostPosted: September 15th, 2016, 22:42
Banned User
You said hard drive model you're using, you can take pictures send label to this help
PostPosted: September 25th, 2016, 9:45
here's the label. i try to start pc with the hd pluged in but it won't start
PostPosted: September 25th, 2016, 15:39
If data is important you should go to pro immediately. Common problem for this model is head crash and very often even pro can't recover data in this case.
PostPosted: September 26th, 2016, 11:42
it'spossible to change some machanical parts?
PostPosted: September 26th, 2016, 12:06
Hi! Yes it is, but should be done by a data recovery proffesional with skills and experience, in a clean room, and with special equipment. After a mechanical part change, hdd should be treated with special care to extract the information on it.
Best,
F.
[quote="scarafaggiomau"]it'spossible to change some machanical parts?
Users browsing this forum: michael chiklis and 171 guests
