 Post subject: Seagate ST3000DM001 stuck BSY Led:0x0BD
PostPosted: March 24th, 2015, 16:45
So I have a Seagate ST3000DM001 Fw:CC47 Stuck in a BSY state
CURRENTLY I connect it to terminal and power up the drive and reports as follows:
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
Trans.
Spin Up
SpinOK
TCC:001F
(P) SATA Reset
LED:000000BD FAddr:0000988E
etc etc etc.......................
Another read I have gotten from this drive when screwing around with shorting:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:001C
RECOV Servo Op=0900 Resp=0005
RECOV Servo Op=0600 Resp=0005
(P) SATA Reset
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005[LBA=0x000042F9]
N02020C20o0o0o0o0o0o0o0o0[LBA=0x000042F9]NO1111
RECOV Servo Op=0155 Resp=0005[LBA=0x00066E3B]
N01010C20o0o0o0o0o0o0o0o0[LBA=0x00066E3C]N0[LBA=0x00066E3F]
N0[LBA=0x00066E40]N0[LBA=0x00066E41]N0[LBA=0x00066E43]N0
RECOV Servo Op=0055 Resp=0005[LBA=0x00028F1D]
N02020C20o0o0o0o0o0o0o0o0[LBA=0x00028F1D]NO1111
RECOV Servo Op=0155 Resp=0005[LBA=0x0008BA5F]
N02020C20o0o0o0o0o0o0o0o0[LBA=0x0008BA5F]NO1111
SimError - Remaining in BootFW
Perform a double download without a power cycle
And another read I got once:
Boot 0x40M
Spin Up
Trans.
Spin Up
SpinOK
TCC:001E
MCMainPOR: Start:
User Data Base 00441118
MCInitialize: Start: Host VBM Size (Bytes): 00000210
Metadata VBM Size (Bytes):
ClearMC: Start Full Starting LBA 0000EA00, Count 00432718
LPC Disc Xfr: EXCEPTION: ProcessRWError: Status =00000002
Next Accessed LBA = 0002BCBB
Retry LBA = 0002BCBB
Retry Level = 00000000
ProcessRWError -Write- at LBA 000002BCBB Sense
Code=40000087!
Next Accessed LBA = 0002BCBC
Retry LBA = 0002BCBC
ProcessRWError -Write- at LBA 000002BCBC Sense
Code=40000087!
Next Accessed LBA = 0002BCE9
Retry LBA = 0002BCE9
ProcessRWError -Write- at LBA 000002BCE9 Sense
Code=40000087!
Next Accessed LBA = 0002BCEB
Retry LBA = 0002BCEB
ProcessRWError -Write- at LBA 000002BCEB Sense
Code=40000087
RECOV Servo Op=0165 Resp=0005
Next Accessed LBA = 0002BCEF
Retry LBA = 0002BCEF
ProcessRWError -Write- at LBA 000002BCEF Sense
Code=40000087!
Next Accessed LBA = 0002BCF1
Retry LBA = 0002BCF1
ProcessRWError -Write- at LBA 000002BCF1 Sense
Code=40000087!
etc etc etc
anyhow sorry If this was too much info to start with but the first section is what my drive currently reports/ normally reports the other 2 I got when attempting to short the read channel and slapping ctrl-z
I have tried to short the read channel (maybe I'm using wrong location)
slap ctrl-Z like no ones business
use card stock on both the motor / heads either or / both.
Anyhow any advice Knowledge or resources would be greatly appreciated.
I'm under the impression that once I get this out of BSY state that I can take a look at smart errors / heads / preamp values and possibly clear smart errors but first step is to bypass this BSY state.
Thanks again Super duper appreciated by this here noob to ttl :mrgreen:
 Post subject: Re: Seagate ST3000DM001 stuck BSY Led:0x0BD
PostPosted: September 27th, 2016, 5:50
Same problem at ST2000DM001 CC26
Any idea?
PostPosted: September 27th, 2016, 12:05
Upload component side pic of PCB so we can see if you're shorting the correct points.
Data Recovery Cape Town
Users browsing this forum: Google [Bot] and 244 guests
