Post new topic Reply to topic  [ 47 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: ST3000DM001 NO ID BSY and Spins.
PostPosted: September 17th, 2015, 10:03
fh83 wrote:
I have an ST3000DM001 7200.14 with the PCB 100664987 Rev B
Rst 0x40M
MC Internal LPC Process
Spin Up
TCC-001D
(P) SATA Reset
MCMainPOR: Start:
Check MCMT Version: Current
MCMainPOR: Non-Init Case
MCMainPOR: EXCEPTION: MCMT PRI copy corrupt
MCMainPOR:  MCMT SEC copy valid
Reconstruction: MCMT Reconstruction Start
  Max number of MC segments 0A61
Nonvolatile MCMT sequence number 003AEAA5
[RSRS] 06DB
ProcessRWError -Read-   at LBA 0000000000058B15  Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 0000000000058B15!
Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
Reconstruction: EXCEPTION: Error in Header
Reconstruction: EXCEPTION: Error in first Header disc sector
I not understand the explanations.:
Make a bridge between pin 1 and 3 ?
or pin 1 + 2 + 3 ?
This is a bridge welding or just for a moment before power the hd ??
Thanks for your help
Just short pin 1 and 3. Try from boot, during boot - pretty much just go to town with the shortening until you get access. You can use any tool to do the shortening, but do not solder.
PostPosted: October 4th, 2016, 11:39
helpdisc wrote:
what was happening when You were shorting it?
i have one like that does not click when I short it
it does not click because the shorting 18 and 16 is wrong. Maybe someone already mentioned it, but for this PCB# 100664987 short points are 18+17 for the read channel
PostPosted: October 4th, 2016, 12:48
Are you sure?
PostPosted: October 4th, 2016, 14:04
Are you sure?
yellow square for read channel. I just had a drive with BSY signal, shorted right before Trans. drops in the terminal and drive comes ready and system files can be modified via Terminal without problems
PostPosted: October 4th, 2016, 20:01
Great! Those are pins 16 & 18, if I'm not mistaken.
PostPosted: December 16th, 2024, 9:20
Sorry for digging this up, Dealing with the same exact issue :)
Boot 0x40M
Spin Up
TCC-0017[0x00026F7C][0x000273E8][0x00027854]
Trans.
Rst 0x40M
Spin Up
TCC-0017
(P) SATA Reset
MCMainPOR: Start:
Nonvolatile MCMT sequence number 00107224
[RSRS] 0080
ProcessRWError -Read-   at LBA 00000000000069FB  Sense Code=40000087
InitiateMarkPendingReallocateRequest for disc_lba: 00000000000069FB!
[SW] 0061
[SW] 002D
[SW] 002A
Continuing after error
ReadFooters (Forward): Segment 0083 StartLBA 0000000000034F68 Starting Footer LBA 0000000000034FB0
  SeqNum 00107228  TotalUserBlocks 0000
  Footer Status = 0000
  Footer Status = 0001
Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch, No Valid Footer  00107228 FFFFEDFF
Reconstruction: ProcessIncompletelyWrittenSegment
PostPosted: December 17th, 2024, 2:43
Well,
Did you solve this case like you read in thread ,Lots of updates have happened in seagate world since those days
Users browsing this forum: No registered users and 61 guests
