 Post subject: 3 T.B 2.5 head swap
PostPosted: October 5th, 2016, 13:44
any one try head swap for 2.5 3tb PEBBLEB family can help me out WD30NMVW, there is no tools from hddsurgery yet and it's too narrow here inside between heads ans heads connector if you open it before . so any clues ,,, it's 10 heads
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
 Post subject: Re: 3 T.B 2.5 head swap
PostPosted: October 5th, 2016, 14:38
necessity is the mother of invention.
Data Recovery Pakistan
PostPosted: October 5th, 2016, 15:02
yes i got your point but i ask if some one can offer any hints with such like this . donors in this model is rare and expensive
Tawfeek Mokhtar
PostPosted: October 5th, 2016, 15:34
tool is in plan :)
HddSurgery - Professional Data Recovery Tools
PostPosted: October 5th, 2016, 15:58
Nothing CAD software and a 3D printer can't solve. :wink:
PostPosted: October 5th, 2016, 16:04
Yes, that is what guys say for recovery also.
Linux and a Freezer....:)
PostPosted: October 5th, 2016, 16:16
I can do these in 10 minutes, with "home-made tools" :-)
PostPosted: October 5th, 2016, 16:58
+1, easy bake oven!
PostPosted: October 6th, 2016, 10:23
it just means you have not used real tools :)
PostPosted: October 6th, 2016, 13:40
This is true, but it's worked every time :-)
PostPosted: October 6th, 2016, 15:22
Yeah, by that definition I've never used any "real tools" either despite doing hundreds upon hundreds of successful head swaps.
It's like anything else, there's more than one way to skin a cat. A tire guy / mechanic could go out and buy a tire mounting machine for $2,000 and have a "real tool", but there's just as many guys out there successfully mounting tires using nothing more than some butane and a lighter. And they can do it in half the time the "real tool" takes. Example: https://youtu.be/3uSn4XtJJx0
I'm sure the guy who spends the money on the $2,000 tool would say that the other way is a "hack" method, but if the end results are the same it's really just a way of justifying the way you prefer to work.
Personally I can't see the need to ever buy a "real tool" for a drive with a parking ramp as my universal homemade ones work every time. However I do prefer a real tool for those which park on the platter (fortunately there are few of those these days).
PostPosted: October 6th, 2016, 17:14
data-medics wrote:
That dude is something else, good one
PostPosted: October 6th, 2016, 20:09
data-medics wrote:
Hahaha. Hilarious! Maybe we could try that on the next stiction case? :lol:
PostPosted: October 9th, 2016, 9:41
So Nikola ,
We Are Real Professionals If We Buy Your Tools And Not If We Do Not ,Is That what you are trying to say .
PostPosted: October 9th, 2016, 9:43
thatdellguy wrote:
+1, easy bake oven!
Very Nice ,
What 3D Printer you Got Brother
PostPosted: October 9th, 2016, 13:32
Amarbir[CDR-Labs] wrote:
So Nikola ,
I understand what you are trying to say, it is hard to read.
All i want to say is , don't compare if you have not tried.
That is what I try to say.
That's all.
PostPosted: October 9th, 2016, 14:25
So Nikola ,
That's all.
this right :)
who will think he can do all the things .. then ... bye bye
PostPosted: October 9th, 2016, 15:03
So Nikola ,
That's all.
Well,
Its perfect to read ,But its pointless arguing with you and as you will have the same answer again and again .Today i Have the entire set of ERTools and i do not have a drive that i cannot handle in my lab .Your rates are and might be justified for your Europian and US clients definitely not for Indian Data recovery companies .
PostPosted: October 9th, 2016, 15:05
H13 wrote:
So Nikola ,
That's all.
this right :)
Well,
If You Are Talking About Physical Work i can handle 99% of the stuff now ,You have a drive to challenge me try me for a change and i will surprise you .
PS : Will not use hdd surgery tools
PostPosted: October 9th, 2016, 15:13
Tawfeek ,
Take a Good Quality 90 Degree Bent Tweezer And Use Precision Nose Plier To Bent The Front Holding Arm Of This Back To 90 Degree ,This will give you a Custom Tweezer That Can Go To Any Depth In Any Drive .Then Use Wire Sleeves Slightly Pressed Making a Oval Shape .Take Heads Out Of The Patient .Then Check The Heads HGA Area is Precise 90 Degree ,If Not Change Your Sleeve Size Or Your Pressed Oval Shape ,Once You Perfect This on Your Defective Head Take a Donor Head Out and Swap To Patient ,Its a Piece of Cake ,Before I Had ERTools I Used The Same Technique But Perfected It .
PS : Nikola You Should Not Make a Few Head Unstuck Tools for 2.5" Drives and Sell It To These European And US Data Recovery Companies ,They Are The Only Once Who Can Really Afford Them .I Am Not Trying To Make Fun Or Poke You This is The God Damn Reality Of Pricing In India . We Cannot Afford Your Tools Simply Put Together
Users browsing this forum: No registered users and 68 guests
