 Post subject: Red 12V register means what again?
PostPosted: October 13th, 2016, 0:48
I have a:
WD Green 3.0TB
WD30EZRX - 00MMMB0
WWN: 50014EE2066919DA
DATE: 24 SEP 2011
DCM: HBRCHT2AAB
DCX: 0M08M16M1
Which is not spinning up. After initialising with my PC3000 it shows green registers on: DWF, DRQ and CRR, the 12V power register is red.
How might i figure out if this is a motor issue or a PCB issue?
This drive belongs to a close friend of mine who lost a bunch of work. :?
 Post subject: Re: Red 12V register means what again?
PostPosted: October 13th, 2016, 2:59
With a multimeter?
PostPosted: October 13th, 2016, 3:32
PCB issue indeed.
Data Recovery Pakistan
PostPosted: October 13th, 2016, 5:13
Durr, probably should have read the manual.
CT to A, B, C had Ohm of 0.6-0.9.
A-B, B-C, A-C had 1.1-1.7 Ohm. (My meter is not good enough for this!)
So the motor seems okay, i will update you all on how the PCB swap goes.
PostPosted: October 13th, 2016, 15:44
I find it quite amusing that you work with hard drives (with a drive that won't spinn), electronics and have invested in a quite expensive program like Pc3000, and still don't know why the 12v power register shows red?!?
http://www.rescue-it.se
Does your manual mention anything about TVS diodes?
PostPosted: October 14th, 2016, 5:33
If the question was to me, Yes, and Power Control info as well. But CleanestRoom might not have a legit one...who knows?
Users browsing this forum: No registered users and 17 guests
