 Post subject: Western digital WD10EACS-00ZJB0 Not Reading Anything
PostPosted: October 18th, 2016, 4:35
hello everyone,
I have this WD hard drive. It comes ready position on PC3000 , id and capacity is okay. i can backup all the modules and rom without any problem
however, when i try to clone this drive onto another hard drive it doesnt read any data and keep software resetting and clicking
tried translator regeneration but it wont complete ,
tried another pcb but same behaviour
anyone could give any idea or some one had similar issue
cheers
wd-hulk.log [1.41 KiB]
Downloaded 574 times
 Post subject: Re: Western digital WD10EACS-00ZJB0 Not Reading Anything
PostPosted: October 18th, 2016, 4:56
did you pull drive from enclousure
could be encryption
PostPosted: October 18th, 2016, 5:50
Check that all heads are working properly
Mikippp
PostPosted: October 18th, 2016, 5:58
hey .. why u are not making heads map first to saperat the reading from each one ?
PostPosted: October 18th, 2016, 6:25
it explains that problem is probably with heads, have you test heads ??
Data Recovery Pakistan
PostPosted: October 18th, 2016, 7:49
Do a heads test in utility.
Web: https://www.day1data.de
PostPosted: October 18th, 2016, 10:31
You van edit head map in RAM. Start first with heads 0 or 1, then you can make adjustment and add good heads. Isolate bad one.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: October 18th, 2016, 14:24
Good advice!
Users browsing this forum: benjaminnelson, jimmydata and 70 guests
cron
