 Post subject: Failed Seagate srd0sd0 - weird noise, what does it mean?
PostPosted: October 24th, 2016, 12:10
I've got a disk here that fell to the floor, and now it's making a sound I have no idea what means. Not a terribly good recording, but it's possible to hear the sound if you turn up the volume.
Any ideas what it means, what part that have failed? The disk does spin up, btw, and the squeaking noise runs a few times before it stops trying.
http://vid21.photobucket.com/albums/b283/appelsinbrus/20161024_150800_zpsolks3my4.mp4
 Post subject: Re: Failed Seagate srd0sd0 - weird noise, what does it mean?
PostPosted: October 24th, 2016, 12:23
Your drive has stiction, you should take it to a DR Pro for free quote and recovery, this is not a DIY
PostPosted: October 24th, 2016, 12:26
What's stiction? Stuck reading heads? Are you sure that's the problem, as it does spin up.
I should mention that I do run a recovery company, only I work with flash medias most of the times, and hhd's like 2 times a year. Won't be opening it if it's a difficult job.
PostPosted: October 24th, 2016, 12:48
hard to hear on the video. Well if the drive spins the heads are dragging on the platter most likely media damage, if you have a cleanroom do a visual inspection and do not power the drive any more. if platter are in good shape, no scratches it may be a chance to recover the data but you will need something like PC3k or MRT to acquire a clone
You can check with Ibas: Data Recovery there in Norway
PostPosted: October 24th, 2016, 15:45
Thats a sound of Seagate with bad heads...not DIY.
http://www.rescue-it.se
PostPosted: October 25th, 2016, 3:12
+1
And by the sound of it, most likely media damage too.
Users browsing this forum: Google [Bot] and 35 guests
