 Post subject: Ubuntu Live DVD Frozen
PostPosted: October 26th, 2016, 2:39
I was using Ubuntu 16.04.1 LTS Live DVD on a tower PC, while shutting down Firefox browser the screen froze. The DVD drive has been making grinding noises with the activity light flashing for 3 days, no response from mouse or keyboard.
I have un-exported bookmarks, is it possible to recover the system without losing data? :?
 Post subject: Re: Ubuntu Live DVD Frozen
PostPosted: October 26th, 2016, 3:13
Or the system get's back on, or your are done.
A live DVD system works on RAM and if you reboot or power off, that info will disappear.
Is the DVD in good conditions? Maybe you can burn another ISO, replace the DVD and hope the reader could read and get un-frozen.
ACELab partner
PostPosted: October 26th, 2016, 4:43
What if I eject the DVD & re-insert it, would that break the loop while retaining the system in memory then maybe it would continue from where it stopped? Any way to access the data from another system on the network? :|
PostPosted: October 26th, 2016, 5:56
If you try and find out...
From the network, I doubt, because the system is frozen...
ACELab partner
PostPosted: October 26th, 2016, 11:45
See if you can run a port scan aimed at the Linux box. If you see an open ssh port you could try to connect over the network with ssh. But it sounds doubtful.
On-Line Data Recovery Consultant. RAID / NAS / Linux Specialist.
Serving clients worldwide since 2011
FreeDataRecovery.us
PostPosted: October 27th, 2016, 8:19
Thanks for the suggestions, no idea how to do a port scan, guess I could learn. Is there anyway to mount a Ram drive remotely, like you can with a HDD? :|
PostPosted: October 27th, 2016, 13:06
Not really possible in your case. You would have had to export the ram drive for sharing via a network protocol like NFS or CIFS/Samba etc. prior to the freeze. You really want to do a port scan to see what your options are if any.
FreeDataRecovery.us
PostPosted: November 1st, 2016, 0:23
The screen was off & I noticed the DVD light stopped flashing, switched the screen on to be greeted by the login screen & mouse pointer moving. Logged in with the default Ubuntu Livecd login ubuntu/blank & everything was still there so I exported my bookmarks. Next headache is fixing boot loader so I can use Ubuntu on the HDD again.
Thank's for staying on board & I hope we all learned from this experience. If you wait long enough some things fix themselves. 8)
PostPosted: November 1st, 2016, 11:53
That's great. I wonder what caused the freeze. You might take a look in the log file to see what was going on at the time.... /var/log/syslog
FreeDataRecovery.us
Users browsing this forum: Google [Bot] and 117 guests
