 Post subject: PreampFaultStatus = 0000YW in SEAGATE ST1000DM003
PostPosted: November 2nd, 2016, 3:36
Experts can you hint what this problem could be due to
PCB is OK. tried another one.
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-001D[0x000064F3][0x000064F3]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddW
PreampFaultStatus = 0000YWMMMMMM
 Post subject: Re: PreampFaultStatus = 0000YW in SEAGATE ST1000DM003
PostPosted: November 2nd, 2016, 9:05
HI,
check the ROm Serial No. is same as HDD.......
PostPosted: November 2nd, 2016, 11:10
1. Non-original ROM
2. Start without 0 head.
3. Problematic heads.
PostPosted: November 2nd, 2016, 15:13
4. can't read sector 64F3
PostPosted: November 3rd, 2016, 4:51
Serial No. is matching with the sticker
1. Non-original ROM
1. Serial no matching. ( ROM is native and Original as the drive belongs to a known client )
2. Without head 0 the sysmtems are same
3. Tried replacing heads. No Change. Patient heads are working in Donor drive.
What could be the solution or a headway ?
PostPosted: November 3rd, 2016, 5:29
Move CAP+SAP+RAP to another fw and try again.
PostPosted: November 3rd, 2016, 8:22
Tried moving CAP+SAP+RAP to donor FW problem remains the same
Patient FW with DONOR's CAP+SAP+RAP works fine on DONOR Drive
PostPosted: November 3rd, 2016, 8:53
Have you tried replacing the PCB?
Web: https://www.day1data.de
PostPosted: November 3rd, 2016, 10:10
Yes
PCB is Okay
PostPosted: November 3rd, 2016, 13:36
Was it at another data recovery place first? Perhaps they wrote the wrong ROM code to it and just modified the serial number so their sabotage wouldn't be obvious.
I only mention it because I seem to be seeing more sabotaged drives lately, probably a result of increasing competition.
PostPosted: November 3rd, 2016, 13:55
agreed.
most likely rom is not native.
Data Recovery Pakistan
PostPosted: November 3rd, 2016, 16:25
Yeah, actually, it seems to wrong/corrupted ROM content....
PostPosted: November 3rd, 2016, 17:12
Does the current symptom match the original symptom as observed by the client?
PostPosted: November 4th, 2016, 5:29
Thank you all for responces. Almost all feel the FW is corrupted or somebody wrote a wrong ROM Code.
The client is 100 % sure that this drive was not given to any Data Recovery Company.
fzabkar : The original problem with the drive when we received was it was Knocking and had bad heads.
After head replacement it started giving above message.
Can anyone take up this job. Can it done supposed if it has FW corruption as all feel.
PostPosted: November 4th, 2016, 13:53
I could try to recover data from drive with this problem. pm me.
PostPosted: November 4th, 2016, 14:21
The reason I asked whether the symptoms had changed was that it was suggested that the drive may have been sabotaged. I wondered if the client had reported a different symptom to the one initially observed by you.
PostPosted: November 5th, 2016, 6:58
Chances of Sabotage are near to zero.
PostPosted: November 8th, 2016, 3:15
Anyone feel this can be done or want to have a look
PM me aprox Charges to do this
PostPosted: November 8th, 2016, 3:44
above statements are contradicting, have you tried shorting read channels ?
PostPosted: November 8th, 2016, 6:45
What i meant here is that when we received the drive it had bad heads and it was knocking.
After head replacement this message started to apear.
I have tried another set of heads also, the problem still the same.
Shorting read channels does not have any effect.
Users browsing this forum: Google [Bot] and 37 guests
