 Post subject: External HDD repair
PostPosted: November 2nd, 2016, 23:53
While trying to repair external hard disk with HDD Regenerator, it says "connect external hard drive as internal". How to do it without removing the case ? I do not want to remove the case as warranty is still there. I want to retrieve the data myself as the cost of data retrieval is equal to the cost of a new external HDD.
 Post subject: Re: External HDD repair
PostPosted: November 3rd, 2016, 2:59
You are almost certainly totally wasting your time.
Trying to "recover" data with hdd regenerator is like trying to cure a headache with a hammer, it will only make it worse.
PostPosted: November 3rd, 2016, 6:07
+1
PostPosted: November 3rd, 2016, 8:46
So you say, no hammer in the first aid kit in Prague? :mrgreen:
Don't run hdd regenerator, do a clone of the drive with DD-Rescue or similar, then retrive your files from the clone...is the external drive a WD?
http://www.rescue-it.se
PostPosted: November 3rd, 2016, 13:41
If you swing that hammer hard enough the headache will go away. :D
Just like if you run HDD Regenerator long enough your need to pay for data recovery will go away. Because in both cases death will result.
Users browsing this forum: Google [Bot] and 74 guests
