 Post subject: eprom fail
PostPosted: November 6th, 2016, 16:22
FW KC48
seagate 500gb
eeprom fail
How to change Sno in eeprom same FW KC48 got from another working HDD same Model
 Post subject: Re: eprom fail
PostPosted: November 6th, 2016, 16:30
You cannot simply change s/n, the ROM contains other data absolutely 100% unique to the drive.
PostPosted: November 6th, 2016, 16:37
How Can I get data back?
PostPosted: November 6th, 2016, 16:53
Why do you think "eeprom" has failed?
Chip is broken?
PostPosted: November 7th, 2016, 3:03
Chip is broken?
Hdd needs to replace pcb eeprom supply voltage pin short
supply voltage to eeprom 0V
I removed eeprom voltage nearly 3 v
i replaced eeprom voltage ok
i swap the suspected eeprom to new board same model except serial no
same voltage loading
eeprom HAS FAILED
NEW eeprom with old board detecting new hard disk
PostPosted: November 10th, 2016, 16:53
I suppose it is a Pharaoh drive ST500DM002 with PN 1BD142. In that case i can recover it without original rom.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 68 guests
