 Post subject: ST2000LM007 - MCMT table is corrupted
PostPosted: November 14th, 2016, 15:14
Hello all,
The first time I've seen one of these in, just received in a few minutes ago. Amazing what they are packing into 7mm.
Drive reaches RDY after about 3 to 4 seconds. Provides ID in PC3000, but Utility does not detect codename, and I presume that Tech mode unlocking is not yet offered on this series:
Model : ST2000LM007-1R8174
Serial : WCC......
Firmware : SBK2
Capacity : 1 863.02 GB (3 907 029 168)
Any sector reads with UNC. Drive sounds OK and remains spinning after power on.
Terminal output below from power, and Test Heads command. Diagnostic port is locked:
Boot 0x80M
QB
Rst 0x80MSrv DETCR init 0x0000
(P) SATA Reset
RAW OFF
PASS
EDAC Value = 00000000FFFFF844
(DOS Table) Worst Count: 00000000 At SU: FFFFFFFF NT: 00000000 OT: 00000000
Intel 6G->3G
Send Status: COMRESET seen
CSpd= 3Gbps
DSC
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/7
F3 7>X
Diagnostic Port Locked
F3 7>
Thoughts and comments are welcome.
J
0161 408 4857
 Post subject: Re: ST2000LM007 - MCMT table is corrupted
PostPosted: November 14th, 2016, 16:49
Looks like a possible issue with System file 346 or possibly the media cache. Though I'd lean toward 346 since it's not getting stuck busy. You'll have to have the latest version of PC-3000 to get around the "diagnostic port locked" issue first though.
PostPosted: November 14th, 2016, 16:52
Nice idea, but I very much doubt pc3k will support FW unlocking on this model :-(
Although I don't have one of these to test, didn't even know they existed!!! :-)
PostPosted: November 15th, 2016, 5:41
PC3000 is up to date with the October release. Currently there is no support for this series of HDD according to ACE TS, and it is currently under development.
I had a PM from some making a suggestion about settings in data extractor that allow for reading small amounts of data (from his own experience), but it has not worked for me. Creating a head-map works OK in DE, but regardless of the settings just UNC gets returned.
Very frustrating being locked out of these drives.
0161 408 4857
PostPosted: November 15th, 2016, 5:48
Yeah, the Media Cache is corrupted. Drive family is Rosewood, I can access FW on these drives.
https://www.mjm.co.uk/
PostPosted: November 15th, 2016, 5:51
Can you please upload a picture of hard disk and its pcb picture also, may be its possible to unlock ROM.
PostPosted: November 15th, 2016, 7:09
Images of drive and PCB are attached. ROM content looks like it is integrated in MCU.
0161 408 4857
PostPosted: November 15th, 2016, 11:01
Yes, can repair FW issues on that drive with FW SBK2.
PostPosted: November 16th, 2016, 2:31
Can you do anything but FW read-write in these drives? Working with SA for instance....
PostPosted: November 16th, 2016, 16:38
The customer decided to not proceed with the recovery attempt. Consequently it has been possible to investigate other aspects of the HDD. These look like a horrible design for dealing with heads. Aside from how compact it is inside the top magnet is effectively part of the lid of the HDD (covered in silver foil), which is then joined with the actual lid with silver foil sticker. Moreover, for these drives to be sealed correctly requires the silver foil which runs around the drive to be intact. Of course this has to be cut through to access the HDA. There are some areas of the lid which are effectively just silver warranty foil, meaning that in certain areas it would be possible to penetrate the HDA with a sharp object like a needle very easily (I suppose older drives do have foil only access points on the side and underside of the HDD). But all in all these look tricky to deal with, and especially hard if a PC shop or individual decides to start tinkering.
As far as I am aware scratchy was able to read and write to the SA using his method. He was also due to swap the heads out of one today - I'm keen to know how it went.
J
0161 408 4857
PostPosted: January 27th, 2017, 8:03
Terminal is locked of this drive. Gets ready but hangs if you try to access any sectors.
Any suggestions ?
Following is the Terminal output
Boot 0x80M[LBA=0x00004995 EC=][LBA=0x00004995 EC=]
RECOV Servo Op=06DF Resp=0005
DSC PASS
RECOV Servo Op=0195 Resp=0005
[LBA=0x00011313 EC=]
RECOV Servo Op=0095 Resp=0005
[LBA=0x00000406 EC=]
(P) SATA Reset
RAW OFF
PASS
(DOS Table) Worst Count: 00000C6C At SU: 001091E7 NT: 00000000 OT: 00000002
(POR) Recover Secondary MCMT Opened
RECOV Servo Op=01A5 Resp=0005
DSC PASS
Recovered
RECOV Servo Op=0395 Resp=0005
ProcessRecoveryComp-2
ERC TO exceeded, orig value in us:FFFFFFFF
MS Read Fails: BF13F878,0000A450
Update Mask - 00000000BF146118 - 00000001 - 00
Update Mask - 00000000BF146119 - 00000001 - 00
Update Mask - 00000000BF14611A - 00000001 - 00
Update Mask - 00000000BF14611B - 00000001 - 00
Update Mask - 00000000BF14611C - 00000001 - 00
Update Mask - 00000000BF14611D - 00000001 - 00
Update Mask - 00000000BF14611E - 00000001 - 00
Update Mask - 00000000BF14611F - 00000001 - 00
RECOV Servo Op=00A5 Resp=0005
RECOV Servo Op=03A5 Resp=0005
(MC POR Duration): 000000CC04
Intel 6G->3G
CSpd= 3Gbps
(DOS) SU:001781E3 Ct:00000A78 Adjusted BRO: 0017E27F0F - 0017E29398
DSC
Starting LBA of RW Request=0017E27F0F Length=0000148A
ProcessRWError -Read- at LBA 0017E27FFE Sense Code=43110081
Hd 3 Err Blk 17E27FFE BER pre -1.951640
ProcessRC: 00000000,00000000ReadContinuous: 17E27FFE,000000EFUnrecovSectorCount:00EF,00EENumUDEs: 000000EF,000000EEPassed: 00000080,000000BF,000000D7Out: SkipLBA: 17E27FFE,17E280EC
ProcessRWError -Read- at LBA 0017E280ED Sense Code=43110081
Hd 3 Err Blk 17E280ED BER pre -1.955715
ProcessRC: 00000001,00000000ReadContinuous: 17E280ED,000000EFUnrecovSectorCount:00EF,00EENumUDEs: 000000EF,000000EEPassed: 00000080,000000BF,000000D7Out: SkipLBA: 17E280ED,17E281DB
ProcessRWError -Read- at LBA 0017E281DC Sense Code=43160080
Hd 3 Err Blk 17E281DC BER pre -1.955987
ProcessRC: 00000001,00000000ReadContinuous: 17E281DC,000000EFUnrecovSectorCount:00EF,00EENumUDEs: 000000EF,000000EEPassed: 00000080,000000BF,000000D7Out: SkipLBA: 17E281DC,17E282CA
ProcessRWError -Read- at LBA 0017E282CB Sense Code=43110081
Hd 3 Err Blk 17E282CB BER pre -1.956225
ProcessRC: 00000001,00000000ReadContinuous: 17E282CB,000000EFUnrecovSectorCount:00EF,00EENumUDEs: 000000EF,000000EEPassed: 00000080,000000BF,000000D7Out: SkipLBA: 17E282CB,17E283B9
ProcessRWError -Read- at LBA 0017E283BA Sense Code=43110081
Hd 3 Err Blk 17E283BA BER pre -1.954977
ProcessRC: 00000001,00000000ReadContinuous: 17E283BA,000000EFUnrecovSectorCount:00EF,00EENumUDEs: 000000EF,000000EEPassed: 00000080,000000BF,000000D7Out: SkipLBA: 17E283BA,17E284A8
Update Mask - 00000000BF142548 - 00000008 - 00
Update Mask - 00000000BF142550 - 00000008 - 00
Update Mask - 00000000BF142558 - 00000008 - 00
Update Mask - 00000000BF142560 - 00000008 - 00
Update Mask - 00000000BF142568 - 00000008 - 00
Update Mask - 00000000BF142570 - 00000008 - 00
Update Mask - 00000000BF142578 - 00000008 - 00
Update Mask - 00000000BF142580 - 00000008 - 00
Update Mask - 00000000BF142588 - 00000008 - 00
Update Mask - 00000000BF142590 - 00000008 - 00
Update Mask - 00000000BF142598 - 00000008 - 00
Update Mask - 00000000BF1425A0 - 00000008 - 00
Update Mask - 00000000BF1425A8 - 00000008 - 00
Update Mask - 00000000BF1425B0 - 00000008 - 00
Update Mask - 00000000BF1425B8 - 00000008 - 00
Update Mask - 00000000BF1425C0 - 00000008 - 00
Update Mask - 00000000BF1425C8 - 00000008 - 00
Update Mask - 00000000BF1425D0 - 00000008 - 00
Update Mask - 00000000BF1425D8 - 00000008 - 00
Update Mask - 00000000BF142898 - 00000008 - 00
Update Mask - 00000000BF1428A0 - 00000008 - 00
Update Mask - 00000000BF142A00 - 00000008 - 00
ProcessRWError -Read- at LBA 0017E28541 Sense Code=43160080
Hd 3 Err Blk 17E28541 BER pre -1.936666
ProcessRC: 00000001,00000000ReadContinuous: 17E28541,00000146TotalEntries:0001 XfrLen:0146UnrecovSectorCount:0001,0000NumUDEs: 00000001,00000000Failed: 40000087Out:
Update Mask - 00000000BF142A08 - 00000008 - 00
Harden - 17E28541
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28541 CHS: 0004F392.03.0098
Assert 741D - LBA 17E28541
Update Mask - 00000000BF142A10 - 00000008 - 00
Update Mask - 00000000BF142A18 - 00000008 - 00
Update Mask - 00000000BF142A20 - 00000008 - 00
Update Mask - 00000000BF142A28 - 00000008 - 00
Update Mask - 00000000BF142A30 - 00000008 - 00
Update Mask - 00000000BF142A38 - 00000008 - 00
Update Mask - 00000000BF142A40 - 00000008 - 00
Update Mask - 00000000BF142A48 - 00000008 - 00
Update Mask - 00000000BF142A50 - 00000008 - 00
Update Mask - 00000000BF142A58 - 00000008 - 00
Update Mask - 00000000BF142A60 - 00000008 - 00
Update Mask - 00000000BF142A68 - 00000008 - 00
Update Mask - 00000000BF142A70 - 00000008 - 00
Update Mask - 00000000BF142A78 - 00000008 - 00
Update Mask - 00000000BF142A80 - 00000008 - 00
Update Mask - 00000000BF142A88 - 00000008 - 00
Update Mask - 00000000BF142A90 - 00000008 - 00
Update Mask - 00000000BF142A98 - 00000008 - 00
Update Mask - 00000000BF142AA0 - 00000008 - 00
Update Mask - 00000000BF142B58 - 00000008 - 00
Update Mask - 00000000BF142B60 - 00000008 - 00
ProcessRWError -Read- at LBA 0017E28570 Sense Code=43160080
Hd 3 Err Blk 17E28570 BER pre -1.952136
ProcessRC: 00000002,00000000ReadContinuous: 17E28570,00000117UnrecovSectorCount:0117,0116NumUDEs: 00000117,00000116Passed: 00000080,000000BF,000000FBOut: SkipLBA: 17E28570,17E28686
ProcessRWError -Read- at LBA 0017E28785 Sense Code=43160080
Hd 3 Err Blk 17E28785 BER pre -1.952758
ProcessRC: 00000001,00000000ReadContinuous: 17E28785,000001CFUnrecovSectorCount:01CF,01CENumUDEs: 000001CF,000001CEPassed: 00000080,000000BF,000001A0Out: SkipLBA: 17E28785,17E28953
Update Mask - 00000000BF144AA0 - 00000008 - 00
Update Mask - 00000000BF144AA8 - 00000008 - 00
Update Mask - 00000000BF1450E8 - 00000008 - 00
Update Mask - 00000000BF1450F0 - 00000008 - 00
Update Mask - 00000000BF1450F8 - 00000008 - 00
Update Mask - 00000000BF145100 - 00000008 - 00
Update Mask - 00000000BF145108 - 00000008 - 00
Update Mask - 00000000BF145110 - 00000008 - 00
Update Mask - 00000000BF145118 - 00000008 - 00
Update Mask - 00000000BF145120 - 00000008 - 00
Update Mask - 00000000BF145128 - 00000008 - 00
Update Mask - 00000000BF145130 - 00000008 - 00
Update Mask - 00000000BF145138 - 00000008 - 00
Update Mask - 00000000BF145140 - 00000008 - 00
Update Mask - 00000000BF145148 - 00000008 - 00
Update Mask - 00000000BF145150 - 00000008 - 00
Update Mask - 00000000BF145158 - 00000008 - 00
Update Mask - 00000000BF1451C8 - 00000008 - 00
Update Mask - 00000000BF1451D0 - 00000008 - 00
Update Mask - 00000000BF1451D8 - 00000008 - 00
Update Mask - 00000000BF1451E0 - 00000008 - 00
ProcessRWError -Read- at LBA 0017E28A3D Sense Code=43160080
Hd 3 Err Blk 17E28A3D BER pre -1.950094
ProcessRC: 00000001,00000000ReadContinuous: 17E28A3D,000000F5TotalEntries:0001 XfrLen:00F5UnrecovSectorCount:0001,0000NumUDEs: 00000001,00000000Failed: 40000087Out:
Update Mask - 00000000BF1451E8 - 00000008 - 00
Harden - 17E28A3D
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28A3D CHS: 0004F38D.03.00E9
Assert 741D - LBA 17E28A3D
Update Mask - 00000000BF1451F0 - 00000008 - 00
Update Mask - 00000000BF1451F8 - 00000008 - 00
Update Mask - 00000000BF145200 - 00000008 - 00
Update Mask - 00000000BF145208 - 00000008 - 00
Update Mask - 00000000BF145210 - 00000008 - 00
Update Mask - 00000000BF145218 - 00000008 - 00
Update Mask - 00000000BF145220 - 00000008 - 00
Update Mask - 00000000BF145228 - 00000008 - 00
Update Mask - 00000000BF145230 - 00000008 - 00
Update Mask - 00000000BF145238 - 00000008 - 00
Update Mask - 00000000BF145240 - 00000008 - 00
Update Mask - 00000000BF145248 - 00000008 - 00
ProcessRWError -Read- at LBA 0017E28B32 Sense Code=43110081
Hd 3 Err Blk 17E28B32 BER pre -1.947638
ProcessRC: 00000002,00000000ReadContinuous: 17E28B32,000000EFUnrecovSectorCount:00EF,00EENumUDEs: 000000EF,000000EEPassed: 00000080,000000BF,000000D7Out: SkipLBA: 17E28B32,17E28C20
Update Mask - 00000000BF146108 - 00000008 - 00
Update Mask - 00000000BF146110 - 00000008 - 00
Update Mask - 00000000BF146118 - 00000008 - 00
ProcessRWError -Read- at LBA 0017E28C24 Sense Code=43160080
Hd 3 Err Blk 17E28C24 BER pre -1.939523
ProcessRC: 00000001,00000000ReadContinuous: 17E28C24,000001DBTotalEntries:0016 XfrLen:01DBUnrecovSectorCount:0016,0015NumUDEs: 00000016,00000015Failed: 40000087Out:
Update Mask - 00000000BF146120 - 00000008 - 00
Harden - 17E28C24
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C24 CHS: 0004F38A.03.0003
Assert 741D - LBA 17E28C24
ProcessRWError -Read- at LBA 0017E28C25 Sense Code=43160080
Hd 3 Err Blk 17E28C25 BER pre -1.947279
ProcessRC: 00000002,00000000ReadContinuous: 17E28C25,000001DATotalEntries:0015 XfrLen:01DAUnrecovSectorCount:0015,0014NumUDEs: 00000015,00000014Failed: 40000087Out:
Update Mask - 00000000BF146128 - 00000008 - 00
Harden - 17E28C25
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C25 CHS: 0004F38A.03.0004
Assert 741D - LBA 17E28C25
ProcessRWError -Read- at LBA 0017E28C26 Sense Code=43160080
Hd 3 Err Blk 17E28C26 BER pre -1.942011
ProcessRC: 00000002,00000000ReadContinuous: 17E28C26,000001D9TotalEntries:0014 XfrLen:01D9UnrecovSectorCount:0014,0013NumUDEs: 00000014,00000013Failed: 40000087Out:
Update Mask - 00000000BF146130 - 00000008 - 00
Harden - 17E28C26
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C26 CHS: 0004F38A.03.0005
Assert 741D - LBA 17E28C26
ProcessRWError -Read- at LBA 0017E28C27 Sense Code=43160080
Hd 3 Err Blk 17E28C27 BER pre -1.945681
ProcessRC: 00000002,00000000ReadContinuous: 17E28C27,000001D8TotalEntries:0013 XfrLen:01D8UnrecovSectorCount:0013,0012NumUDEs: 00000013,00000012Failed: 40000087Out:
Update Mask - 00000000BF146138 - 00000008 - 00
Harden - 17E28C27
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C27 CHS: 0004F38A.03.0006
Assert 741D - LBA 17E28C27
ProcessRWError -Read- at LBA 0017E28C28 Sense Code=43160080
Hd 3 Err Blk 17E28C28 BER pre -1.944854
ProcessRC: 00000002,00000000ReadContinuous: 17E28C28,000001D7TotalEntries:0012 XfrLen:01D7UnrecovSectorCount:0012,0011NumUDEs: 00000012,00000011Failed: 40000087Out:
Update Mask - 00000000BF146140 - 00000008 - 00
Harden - 17E28C28
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C28 CHS: 0004F38A.03.0007
Assert 741D - LBA 17E28C28
ProcessRWError -Read- at LBA 0017E28C29 Sense Code=43160080
Hd 3 Err Blk 17E28C29 BER pre -1.943784
ProcessRC: 00000002,00000000ReadContinuous: 17E28C29,000001D6TotalEntries:0011 XfrLen:01D6UnrecovSectorCount:0011,0010NumUDEs: 00000011,00000010Failed: 40000087Out:
Update Mask - 00000000BF146148 - 00000008 - 00
Harden - 17E28C29
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C29 CHS: 0004F38A.03.0008
Assert 741D - LBA 17E28C29
ProcessRWError -Read- at LBA 0017E28C2A Sense Code=43160080
Hd 3 Err Blk 17E28C2A BER pre -1.942800
ProcessRC: 00000002,00000000ReadContinuous: 17E28C2A,000001D5TotalEntries:0010 XfrLen:01D5UnrecovSectorCount:0010,000FNumUDEs: 00000010,0000000FFailed: 40000087Out:
Update Mask - 00000000BF146150 - 00000008 - 00
Harden - 17E28C2A
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C2A CHS: 0004F38A.03.0009
Assert 741D - LBA 17E28C2A
ProcessRWError -Read- at LBA 0017E28C2B Sense Code=43160080
Hd 3 Err Blk 17E28C2B BER pre -1.943004
ProcessRC: 00000002,00000000ReadContinuous: 17E28C2B,000001D4TotalEntries:000F XfrLen:01D4UnrecovSectorCount:000F,000ENumUDEs: 0000000F,0000000EFailed: 40000087Out:
Update Mask - 00000000BF146158 - 00000008 - 00
Harden - 17E28C2B
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C2B CHS: 0004F38A.03.000A
Assert 741D - LBA 17E28C2B
ProcessRWError -Read- at LBA 0017E28C2C Sense Code=43160080
Hd 3 Err Blk 17E28C2C BER pre -1.941530
ProcessRC: 00000002,00000000ReadContinuous: 17E28C2C,000001D3TotalEntries:000E XfrLen:01D3UnrecovSectorCount:000E,000DNumUDEs: 0000000E,0000000DFailed: 40000087Out:
Update Mask - 00000000BF146160 - 00000008 - 00
Harden - 17E28C2C
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C2C CHS: 0004F38A.03.000B
Assert 741D - LBA 17E28C2C
ProcessRWError -Read- at LBA 0017E28C2D Sense Code=43160080
Hd 3 Err Blk 17E28C2D BER pre -1.942217
ProcessRC: 00000002,00000000ReadContinuous: 17E28C2D,000001D2TotalEntries:000D XfrLen:01D2UnrecovSectorCount:000D,000CNumUDEs: 0000000D,0000000CFailed: 40000087Out:
Update Mask - 00000000BF146168 - 00000008 - 00
Harden - 17E28C2D
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C2D CHS: 0004F38A.03.000C
Assert 741D - LBA 17E28C2D
ProcessRWError -Read- at LBA 0017E28C2E Sense Code=43160080
Hd 3 Err Blk 17E28C2E BER pre -1.946856
ProcessRC: 00000002,00000000ReadContinuous: 17E28C2E,000001D1TotalEntries:000C XfrLen:01D1UnrecovSectorCount:000C,000BNumUDEs: 0000000C,0000000BFailed: 40000087Out:
Update Mask - 00000000BF146170 - 00000008 - 00
Harden - 17E28C2E
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C2E CHS: 0004F38A.03.000D
Assert 741D - LBA 17E28C2E
ProcessRWError -Read- at LBA 0017E28C2F Sense Code=43160080
Hd 3 Err Blk 17E28C2F BER pre -1.944125
ProcessRC: 00000002,00000000ReadContinuous: 17E28C2F,000001D0TotalEntries:000B XfrLen:01D0UnrecovSectorCount:000B,000ANumUDEs: 0000000B,0000000AFailed: 40000087Out:
Update Mask - 00000000BF146178 - 00000008 - 00
Harden - 17E28C2F
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C2F CHS: 0004F38A.03.000E
Assert 741D - LBA 17E28C2F
ProcessRWError -Read- at LBA 0017E28C30 Sense Code=43160080
Hd 3 Err Blk 17E28C30 BER pre -1.940495
ProcessRC: 00000002,00000000ReadContinuous: 17E28C30,000001CFTotalEntries:000A XfrLen:01CFUnrecovSectorCount:000A,0009NumUDEs: 0000000A,00000009Failed: 40000087Out:
Update Mask - 00000000BF146180 - 00000008 - 00
Harden - 17E28C30
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C30 CHS: 0004F38A.03.000F
Assert 741D - LBA 17E28C30
ProcessRWError -Read- at LBA 0017E28C31 Sense Code=43160080
Hd 3 Err Blk 17E28C31 BER pre -1.941405
ProcessRC: 00000002,00000000ReadContinuous: 17E28C31,000001CETotalEntries:0009 XfrLen:01CEUnrecovSectorCount:0009,0008NumUDEs: 00000009,00000008Failed: 40000087Out:
Update Mask - 00000000BF146188 - 00000008 - 00
Harden - 17E28C31
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C31 CHS: 0004F38A.03.0010
Assert 741D - LBA 17E28C31
ProcessRWError -Read- at LBA 0017E28C32 Sense Code=43160080
Hd 3 Err Blk 17E28C32 BER pre -1.948363
ProcessRC: 00000002,00000000ReadContinuous: 17E28C32,000001CDTotalEntries:0008 XfrLen:01CDUnrecovSectorCount:0008,0007NumUDEs: 00000008,00000007Failed: 40000087Out:
Update Mask - 00000000BF146190 - 00000008 - 00
Harden - 17E28C32
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C32 CHS: 0004F38A.03.0011
Assert 741D - LBA 17E28C32
ProcessRWError -Read- at LBA 0017E28C33 Sense Code=43160080
Hd 3 Err Blk 17E28C33 BER pre -1.949623
ProcessRC: 00000002,00000000ReadContinuous: 17E28C33,000001CCTotalEntries:0007 XfrLen:01CCUnrecovSectorCount:0007,0006NumUDEs: 00000007,00000006Failed: 40000087Out:
Update Mask - 00000000BF146198 - 00000008 - 00
Harden - 17E28C33
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C33 CHS: 0004F38A.03.0012
Assert 741D - LBA 17E28C33
ProcessRWError -Read- at LBA 0017E28C34 Sense Code=43160080
Hd 3 Err Blk 17E28C34 BER pre -1.947814
ProcessRC: 00000002,00000000ReadContinuous: 17E28C34,000001CBTotalEntries:0006 XfrLen:01CBUnrecovSectorCount:0006,0005NumUDEs: 00000006,00000005Failed: 40000087Out:
Update Mask - 00000000BF1461A0 - 00000008 - 00
Harden - 17E28C34
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C34 CHS: 0004F38A.03.0013
Assert 741D - LBA 17E28C34
ProcessRWError -Read- at LBA 0017E28C35 Sense Code=43160080
Hd 3 Err Blk 17E28C35 BER pre -1.945490
ProcessRC: 00000002,00000000ReadContinuous: 17E28C35,000001CATotalEntries:0005 XfrLen:01CAUnrecovSectorCount:0005,0004NumUDEs: 00000005,00000004Failed: 40000087Out:
Update Mask - 00000000BF1461A8 - 00000008 - 00
Harden - 17E28C35
InitiateMarkPendingReallocateRequest for disc_lba: 0017E28C35 CHS: 0004F38A.03.0014
Assert 741D - LBA 17E28C35
ProcessRWError -Read- at LBA 0017E28C36 Sense Code=43160080
PostPosted: January 27th, 2017, 18:04
Nice log, Rob :)
the drive has some head failure almost surely, plus it is locked, has signed fw, pc3k can't work with it, but of course it is possible to get around the problem.
PostPosted: January 31st, 2017, 3:08
Thanks Pepe
Heads Changed
Problem remains the same. No Changes.
Any tips
PostPosted: January 31st, 2017, 12:48
I can do it if that's an option.
PostPosted: March 9th, 2017, 4:55
Has been unlocked, after unlocking can list the following list
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>
ASCII Diag mode
F3 T>/c
F3 C>Q
Online CR: Rev 0011.0000, Flash, Abort
Online ESC: Rev 0011.0000, Flash, Abort Looping Command or Batch File
Online ' ': Rev 0001.0000, Overlay, Pause Output
Online '.': Rev 0013.0000, Overlay, Display Active Status
Online '?': Rev 0011.0001, Overlay, Display Diagnostic Buffer Information
Online '`': Rev 0017.0000, Flash, Display Read/Write Statistics
Online '$': Rev 0017.0000, Flash, Display Read/Write Statistics By Zone
Online '': Rev 0011.0000, Overlay, Toggle EIB-Specific R/W Tracing
Online ^D: Rev 0011.0001, Overlay, Toggle R/W Tracing
Online ^N: Rev 0011.0001, Overlay, Toggle R/W Tracing
Online ^W: Rev 0011.0000, Flash, Enable and Init RW Statistics
Online ^O: Rev 0004.0000, Overlay, Advance Servo Tracing State
Online ':': Rev 0001.0000, Flash, PrepSecondaryOnlineCmd
Online '!': Rev 0012.0000, Overlay, Display Current Read Channel Settings
Online '<': Rev 0011.0000, Overlay, Decrement Read/Write Scope Sync
Online '>': Rev 0011.0000, Overlay, Increment Read/Write Scope Sync
Online '~': Rev 0015.0000, Overlay, Display Native Interface Command State
Online ^A: Rev 0019.0000, Flash, Display Firmware Revision
Online ^B: Rev 0015.0000, Overlay, Get Thermistor Temperature
Online ^C: Rev 0011.0000, Overlay, Firmware Reset
Online ^E: Rev 0011.0000, Overlay, Display Native Interface Configuration
Online ^F: Rev 0011.0001, Overlay, Display Native Interface Read Cache Information
Online ^H: Rev 0001.0000, Overlay, Display Performance Statistics
Online ^I: Rev 0011.0000, Overlay, Display Controller Registers
Online ^K: Rev 0011.0000, Overlay, Display DST Status
Online ^L: Rev 0026.0000, Overlay, Display Sign On Message
Online ^P: Rev 0011.0000, Overlay, Toggle Diag Idle Mode
Online ^Q: Rev 0011.0000, Overlay, Resume Interface Task
Online ^R: Rev 0011.0000, Flash, Enable ASCII Online Serial Port Mode
Online ^S: Rev 0011.0000, Overlay, Pause Interface Task
Online ^T: Rev 0011.0000, Flash, Enable ESLIP Serial Port Mode
Online ^U: Rev 0011.0000, Overlay, Display Congen
Online ^V: Rev 0011.0000, Overlay, Toggle Interface Command Echo
Online ^X: Rev 0014.0000, Overlay, Display Native Interface and Read/Write Command History
Online ^Y: Rev 0011.0000, Overlay, Display DST Status
Online ^Z: Rev 0011.0000, Flash, Enable ASCII Diagnostic Serial Port Mode
Online ^\: Rev 0012.0000, Overlay, Toggle Debug Display Enable
Level : '`': Rev 0017.0000, Flash, QMON Counters
Level : '$': Rev 0017.0000, Flash, QMON Stats
Level : 'C': Rev 0001.0000, Overlay, Dump Seacorder Log
Level : 'D': Rev 0001.0000, Flash, Dump CFD Log
Level : 'W': Rev 0001.0000, Overlay, Dump Servo Capture Log
Level : 'E': Rev 0001.0000, Flash, Dump EERT Log
Level : 'S': Rev 0001.0000, Overlay, Dump Servo Seek Failure Log
Level : '.': Rev 0001.0000, Flash, Display R/W Status
All Levels CR: Rev 0011.0000, Flash, Abort
All Levels '/': Rev 0001.0000, Flash, Change Diagnostic Command Level, /[Level]
All Levels '+': Rev 0012.0000, Flash, Peek Memory Byte, +[AddrHi],[AddrLo],[NotUsed],[NumBytes]
All Levels '-': Rev 0012.0000, Flash, Peek Memory Word, -[AddrHi],[AddrLo],[NotUsed],[NumBytes]
All Levels '=': Rev 0011.0002, Flash, Poke Memory Byte, =[AddrHi],[AddrLo],[Data],[Opts]
All Levels '@': Rev 0001.0000, Overlay, Batch File Label, @[LabelNum]
All Levels '|': Rev 0001.0000, Overlay, Batch File Terminator, |
All Levels '*': Rev 0011.0000, Overlay, Special Batch File Function, *[FuncId],[FuncParm0],[FuncParm1]
All Levels 'A': Rev 0013.0001, Overlay, Set Test Space, A[OptsOrParmSelect],[ParmValue],[AddrType],[HdForCylLimit]
All Levels 'L': Rev 0001.0002, Overlay, Enable Looping, L[Opts],[CountOrStopOnErrCode]
Level 1 'N': Rev 0017.0006, Flash, SMART Control, N[SubCmd],[SubCmdParm0],[SubCmdParm1]
Level 1 'd': Rev 0002.0000, Flash, Get Stack Usage Information, d
Level 1 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 1 'D': Rev 0011.0001, Overlay, Memory Block Display, D[AddrHi],[AddrLo],[CompVal],[NumBytes],[Opts],[SizeInBytes]
Level 1 'G': Rev 0011.0000, Overlay, Generic Read/Write Request, G[Parm0],[Parm1],[Parm2],...[Parm9]
Level 1 'S': Rev 0011.0001, Overlay, Edit Processor Memory Byte, S[AddrHi],[AddrLo],[MemValue],[NumBytes],[Opts]
Level 1 'U': Rev 0011.0001, Overlay, Edit Buffer Memory Byte, U[AddrHi],[AddrLo],[MemValue],[NumBytes]
Level 1 'c': Rev 0011.0000, Overlay, Buffer Compare, c[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level 1 'e': Rev 0011.0000, Overlay, Spin Down and Reset Drive, e[MsecDelay],[Opts]
Level 1 'j': Rev 0001.0000, Overlay, Display Hardware Jumper Setting, j[HardwareJumperSelect]
Level 1 'm': Rev 0011.0001, Overlay, Edit Processor Memory Word, m[AddrHi],[AddrLo],[MemValue],[NumBytes],[Opts]
Level 1 's': Rev 0001.0000, Overlay, Call SDBP Cmd, s[Parm1],[Parm2],[Parm3]
Level 2 'H': Rev 0011.0000, Flash, Select Logical Head, H[Hd],[SkType],[Options]
Level 2 'x': Rev 0032.0001, Flash, Display Zone Information, x[Partition],[Hd],[Zone],[Options]
Level 2 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 2 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level 2 'D': Rev 0003.0000, Overlay, LdpcIterationControl, D[itratn cnt],[glbl itratn],[BERP opts],[erasure],[slidewindowjog_sz],[ext itratn],[slidingwindow itratn],[MAMR itratn]
Level 2 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 2 'F': Rev 0013.0000, Overlay, Modify Track Defect List, F[PSctr/LBA],[Action],[SourceMask],[BBMMask]
Level 2 'I': Rev 0017.0000, Overlay, Display / Modify Adaptive Parameter, I,[GroupId]
Level 2 'J': Rev 0001.0000, Overlay, Particle Sweep, J[ Start Cyl ],[ End Cyl ],[ Duration mSec ],[ Dwell mSec ],[ JIT mode ]
Level 2 'K': Rev 0011.0000, Overlay, Set Tracking Offset, K[OffsetValue],[PersOrTempOpt],[UnitsOpt],[ChanReload]
Level 2 'M': Rev 0012.0000, Overlay, Set Diag Idle Mode, M[ModeSelect],[ModeMask],[ResetToPowerOn]
Level 2 'N': Rev 0001.0000, Overlay, Set Direct Write Mode, N[EnableDirWrtModeOpt], [Toggle Test Mode]
Level 2 'O': Rev 0011.0000, Overlay, Seek Repeatedly Between Physical Cylinders, O[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 2 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level 2 'Q': Rev 0011.0001, Overlay, Write, Read, Read CHS, Q[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'R': Rev 0011.0003, Overlay, Read CHS, R[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 2 'T': Rev 0017.0000, Overlay, Measure Throughput, T[Opts],[CylSkew],[HeadSkew],[MiniZoneSkew],[SkewStep],[LengthInTracksOrBands],[OffsetInTracksOrBands],[NumberOfRetries]
Level 2 'U': Rev 0011.0000, Overlay, Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 2 'V': Rev 0011.0001, Overlay, Read Verify CHS, V[Sec],[NumSecs],[CompareBlk],[Opts]
Level 2 'W': Rev 0011.0002, Overlay, Write CHS, W[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 2 'X': Rev 0016.0001, Overlay, Display Track Information, X[LogCyl],[Hd],[SysAreaOpt],[Opts],[RowsPerPage]
Level 2 'Y': Rev 0012.0001, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],,[Options]
Level 2 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z
Level 2 'a': Rev 0002.0000, Overlay, Measure Optimum Skew, a
Level 2 'b': Rev 0017.0000, Overlay, BER by Hd / Zone, b[hd][,zone]
Level 2 'c': Rev 0011.0000, Overlay, Buffer Compare, c[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level 2 'e': Rev 0001.0000, Overlay, Clean Track Range, e[StartLogicalTrack],[EndLogicalTrack],[Head]
Level 2 'h': Rev 0018.0000, Overlay, Translate Physical Sector, h[Sec],[NumSecs]
Level 2 'i': Rev 0011.0000, Overlay, Display Defects On Current Track, i[Print Summary]
Level 2 'j': Rev 0011.0001, Overlay, Read Wedge, j[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opts],[RegAddr0],...,[RegAddr13]
Level 2 'k': Rev 0001.0000, Overlay, Set User Cylinder/Head/MiniZone Skew, k[CylSkew],[HeadSkew],[MiniZoneSkew]
Level 2 'l': Rev 0018.0000, Overlay, Translate Logical Sector, l[Sec],[NumSecs]
Level 2 'o': Rev 0002.0002, Overlay, Corrupt LBA, o[Lba],[NumBlocks],[BurstSpan],[BurstOffset],[NumberOfRandomCorrupt],[Flags]
Level 2 'r': Rev 0011.0001, Overlay, Read Long CHS or Read System CHS, r[LongSec],[LongSecsOrSysSec],[SysSecs],[LongPhySecOpt],[LongOpts],[SysOpts]
Level 2 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 2 't': Rev 0018.0000, Overlay, Translate Wedge, t[Wdg],[NumWdgs]
Level 2 'u': Rev 0011.0000, Overlay, Enable/Disable Channel/Preamp Register Display, u[EnableDisableOpt]
Level 2 'v': Rev 0011.0000, Overlay, Convert Data Track Percentage To Servo Offset Count, v[Percentage]
Level 2 'w': Rev 0012.0001, Overlay, Write Long CHS or Write System CHS, w[LongSec],[LongSecsOrSysSec],[SysSecs],[LongPhySecOpt],,[SysOpts],[SysValidKey]
Level 2 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level 2 'z': Rev 0012.0001, Overlay, Write Wedge, z[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opt],[RegAddr0],...,[RegAddr13],[TSpacing]
Level 2 '7': Rev 0011.0001, Overlay, Write Verify CHS, 7[Sec],[NumSecs],[WrBufBlk],[Opts]
Level 3 'H': Rev 0011.0000, Flash, Select Logical Head, H[Hd],[SkType],[Options]
Level 3 'D': Rev 0011.0000, Overlay, Measure Seek Access Time, D[SkLength],[SkType],[NumSks]
Level 3 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 3 'O': Rev 0011.0000, Overlay, Seek Repeatedly Between Physical Cylinders, O[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 3 'Q': Rev 0011.0001, Overlay, Write, Read, Write, Read CHS, Q[Sec],[NumSecs],[Opts]
Level 3 'R': Rev 0012.0000, Overlay, Read Current Servo Destination, R
Level 3 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 3 'U': Rev 0011.0000, Overlay, Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 3 'V': Rev 0012.0000, Overlay, Read or Write Power ASIC Register, V[RegAddr],[RegValue],[WrOpt]
Level 3 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z
Level 3 'b': Rev 0001.0000, Overlay, LoadUnloadHeads, b[Cmd],[Velocity],[Dwell],[Lock]
Level 3 'f': Rev 0013.0000, Overlay, Real Time Servo Trace, f[SubCmd],[SubPrm0],[SubPrm1],[SubPrm2]
Level 3 'p': Rev 0018.0000, Overlay, Translate Physical Sector, p[Sec],[NumSecs]
Level 3 'q': Rev 0018.0000, Overlay, Translate Logical Sector, q[Sec],[NumSecs]
Level 3 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 4 'H': Rev 0011.0000, Flash, Select Logical Head, H[Hd],[SkType],[Options]
Level 4 'B': Rev 0011.0000, Overlay, Enable / Disable RVFF, B[NewRvffControlMode]
Level 4 'D': Rev 0011.0000, Overlay, Measure Seek Access Time, D[SkLength],[SkType],[NumSks]
Level 4 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 4 'F': Rev 0001.0000, Overlay, Fast IO Cmd, F[NumRevs],[Attrib1],[Attrib2],[Attrib3]
Level 4 'K': Rev 0011.0000, Overlay, Set Tracking Offset, K[OffsetValue],[PersOrTempOpt],[UnitsOpt],[ChanReload]
Level 4 'O': Rev 0011.0000, Overlay, Display Micro Jog for Logical Cylinder and Head, O[LogCyl],[Hd],[Opts],[SysAreaOpt]
Level 4 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 4 'U': Rev 0011.0000, Overlay, Servo Batch Test sub commands, U[SubCmd],[SubCmdParm0],[SubCmdParm1],[SubCmdParm2]
Level 4 'c': Rev 0001.0000, Overlay, Find Min Or Max Cylinders c[Head],[Mode],[RangeMultiplier],[RetryCountLimit],[FilterTimeConstant]
Level 4 'e': Rev 0011.0000, Overlay, Enable / Disable PES Output, e[PesLeftShiftCnt],[DisablePesOut]
Level 4 'g': Rev 0001.0000, Overlay, Display Servo Sector Error Log, g
Level 4 'k': Rev 0001.0000, Overlay, Get VGA Data, k[OpType],[StartHt],[EndHt],[HtInc]
Level 4 'l': Rev 0011.0000, Overlay, Scan Track for Servo Defects and ZAP, l[RdPositionOpt]
Level 4 'q': Rev 0001.0000, Overlay, Display Servo Event Log, q
Level 4 's': Rev 0002.0000, Overlay, Display Servo Sector Error Count, s
Level 4 't': Rev 0011.0000, Overlay, Display / Modify ZAP Table, t[EntryNum],[EntryValue]
Level 4 'u': Rev 0011.0000, Overlay, Set Seek Speed, u[Opts],[SkSpeed]
Level 4 'v': Rev 0011.0000, Overlay, Butterfly Seek Test, v[StartPhyCyl0],[StartPhyCyl1],[NumSkPairs],[NumSeconds],[Hd]
Level 5 'E': Rev 0001.0000, Flash, Measure Disc Eccentricity
Level 5 'R': Rev 0011.0000, Flash, Read Servo RAM at Address, R[Addr],[NumBytes]
Level 5 'S': Rev 0011.0000, Flash, Enter Servo Matlab Shell, S
Level 5 'B': Rev 0011.0000, Overlay, Servo Bode Plot, B[BodeType],[InjAmp],[Fmin],[Fmax],[NumFreq],[NumSamples],[EnableTracing]
Level 5 'C': Rev 0011.0000, Overlay, Generic Servo Command, C[CmdNum],[Parm1],...[Parm7]
Level 5 'D': Rev 0011.0000, Overlay, Read / Unlock DDR Buffer, D[OperateCode]
Level 5 'F': Rev 0011.0001, Overlay, DriveFreeFallProtection, F[OpCode],[FreeFallSen],[TumbleSen],[SimDur],[SimSensorOutputs]
Level 5 'G': Rev 0011.0000, Overlay, Select Servo Controller, G[Head],[Controller],[InputShift]
Level 5 'P': Rev 0004.0000, Overlay, PZT Test, P[OperationId],[DAC gain]
Level 5 'U': Rev 0011.0000, Overlay, Enable / Disable Servo Updates, U[VcmDacUpdateOpt],[AToDUdateOpt]
Level 5 'W': Rev 0011.0000, Overlay, Write Servo RAM at Address, W[Addr],[NumBytes],[Data]
Level 5 'Z': Rev 0011.0000, Overlay, Read Zap from Disc to Table, Z
Level 5 'b': Rev 0001.0000, Overlay, Bist Functionality, b[FunctionCode],[Mode]
Level 5 'd': Rev 0011.0000, Overlay, Disable / Enable Servo ZAP coefficients and ZAP read, d[ZapControlMode]
Level 5 'e': Rev 0001.0000, Overlay, Enable / Disable Shock Sensor, e[Operation]
Level 5 'i': Rev 0011.0000, Overlay, Read Servo Symbol Table at Index, i[Index]
Level 5 'p': Rev 0001.0000, Overlay, Set Power Mode, p[PowerMode]
Level 5 'r': Rev 0011.0000, Overlay, Read Servo RAM at Index, r[Index],[NumBytes],[ByteOffset]
Level 5 'w': Rev 0011.0000, Overlay, Write Servo RAM at Index, w[Index],[NumBytes],[Data],[ByteOffset]
Level 6 'B': Rev 0011.0000, Overlay, Run Batch File, B[BatchFileNum],[DisplayOpt]
Level 6 'D': Rev 0011.0000, Overlay, Display Batch File, D[BatchFileNum]
Level 6 'E': Rev 0011.0000, Overlay, Enter Batch File, E[BatchFileNum]
Level 7 'G': Rev 0003.0000, Flash, MonitorBackgroundTasks, G[SubCmd]
Level 7 'H': Rev 0011.0000, Flash, Select Logical Head, H[Hd],[SkType],[Options]
Level 7 'x': Rev 0032.0001, Flash, Display Zone Information, x[Partition],[Hd],[Zone],[Options]
Level 7 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level 7 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level 7 'D': Rev 0014.0000, Overlay, Display Temperature, D,[DevSelect]
Level 7 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level 7 'I': Rev 0017.0000, Overlay, Display / Modify Adaptive Parameter, I,[GroupId]
Level 7 'K': Rev 0011.0000, Overlay, Set Track Format, K[UserAreaTrkFormatType],[SysAreaTrkFormatType]
Level 7 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level 7 'Q': Rev 0011.0001, Overlay, Write, Read, Read CHS, Q[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'R': Rev 0011.0003, Overlay, Read CHS, R[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 7 'U': Rev 0015.0005, Overlay, Preamp Temperature Adjust, U[TweakTemperature],[Partition],[Hd],[Zone],[Opts],[WrPreht],[WrWrtHt],[WrRdHt],[RdPreht],[RdWrtHt],[RdRdHt],[RelHum]
Level 7 'W': Rev 0011.0002, Overlay, Write CHS, W[Sec],[NumSecs],,[PhyOpt],[Opts]
Level 7 'X': Rev 0011.0000, Overlay, Display Preamp Head Resistance
Level 7 'Y': Rev 0012.0001, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],,[Options]
Level 7 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z
Level 7 'b': Rev 0012.0000, Overlay, Erase Track, b[AdjacentTrkCnt],[EraseCntPerTrk],[AcEraseOpt]
Level 7 'c': Rev 0011.0000, Overlay, Off Track Capability, c[Sec],[NumSecs],[SecIncrement],[Offset]
Level 7 'd': Rev 0002.0000, Overlay, Create Recoverable Read Error, d LBA,[min],[max],[cnt],[sev]
Level 7 'e': Rev 0001.0000, Overlay, BipsControl, e[BipsControlOptions]
Level 7 'g': Rev 0001.0000, Overlay, Sector Based BER, g[sctr],[len],[option]
Level 7 'h': Rev 0011.0001, Overlay, Mark Media Flaw, h[PhyCyl],[Hd],[PhySec],[UndisturbedRadius],[EraseBandTrks],[PtrLen],[WgSpec],[Od/Id]
Level 7 'i': Rev 0011.0000, Overlay, Generic Read/Write Request, i[Parm0],[Parm1],[Parm2],...[Parm9]
Level 7 'j': Rev 0001.0000, Overlay, GetSetLongErasureMaskTableCount, L[Mission],[Value]
Level 7 'm': Rev 0028.0000, Overlay, Display DOS Information, m[Flags],[LBA],[MinCnt]
Level 7 'r': Rev 0012.0000, Overlay, Read Non-Volatile Adaptive Parameters, r[Opts]
Level 7 's': Rev 0011.0000, Overlay, Write Peripheral Register - channel or preamp, s[OpType],[RegAddr],[RegValue],[RegMask],[RegPagAddr]
Level 7 't': Rev 0012.0000, Overlay, Read Peripheral Register - channel or preamp, t[OpType],[RegAddr],[NumRegs],[RegMask],[RegPagAddr]
Level 7 'u': Rev 0011.0000, Overlay, Enable/Disable Write Fault, u[Op]
Level 7 'v': Rev 0002.0000, Overlay, GetPvt, v[StartingSuperBlock],[NumSuperBlocks],[OutputFormat],[Options]
Level 7 'w': Rev 0011.0000, Overlay, Save Adaptives To Flash, w[Seg],,22
Level 7 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level 8 'C': Rev 0011.0000, Overlay, Servo Diag Sub Cmds, C[SubCmd],[Parm0],[Parm1],[Parm2]
Level 8 'R': Rev 0012.0000, Overlay, Read Current Servo Destination, R
Level 8 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level 8 'U': Rev 0011.0000, Overlay, Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level 8 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z
Level 8 'd': Rev 0001.0000, Overlay, Head Smash Test, d[HeadDirection],[AccelerationDuration],[DecelerationDuration],[AccelerationCurrent],[DecelerationCurrent]
Level A 'F': Rev 0018.0001, Flash, Translate LBA, F[LbaHi],[LbaLo],[SysAreaOpt],[NumLbas]
Level A 'G': Rev 0018.0000, Flash, Translate Host LBA, G[LbaHi],[LbaLo],[NumLbas]
Level A 'C': Rev 0018.0000, Overlay, Translate PBA, C[PbaHi],[PbaLow],[NumPbas]
Level A 'D': Rev 0018.0000, Overlay, Translate Symbols From Index, D[PhyCyl],[Hd],[Sfi],[NumSfis]
Level A 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level A 'M': Rev 0011.0000, Overlay, Set Controller Test Port, M[Port],[Value]
Level A 'P': Rev 0013.0001, Overlay, Merge Alt List into Slip List, P[RADIAL_PAD_IN_TRACKS],[CIRCUMFERENTIAL_PAD_SINGLE_IN_WEDGES],[CIRCUMFERENTIAL_PAD_MULTI_IN_WEDGES],[OPTIONS]
Level A 'Q': Rev 0011.0001, Overlay, Write, Read, Read LBA, Q[Lba],[NumLbas],[Opts]
Level A 'R': Rev 0012.0000, Overlay, Read LBA, R[Lba],[NumLbas],,[Opts]
Level A 'S': Rev 0011.0000, Overlay, Seek to LBA, S[LbaHi],[LbaLo],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level A 'T': Rev 0001.0000, Overlay, GetLbaTracks, T[Zone],[Head]
Level A 'V': Rev 0001.0001, Overlay, SeqThroughputByLba, V[Operation],[StartHostLba],[EndHostLba],[XferLenInHostBlks],[SampleCount],[Options]
Level A 'W': Rev 0012.0001, Overlay, Write LBA, W[Lba],[NumLbas],,[Opts],[WSPattern]
Level A 'Y': Rev 0012.0001, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],,[Options]
Level A 'c': Rev 0018.0000, Overlay, Translate Logical Cylinder, Logical Head and Logical Sector, c[Cyl],[Hd],[Sec],[SysAreaOpt],[NumSecs]
Level A 'd': Rev 0018.0000, Overlay, Translate Physical Cylinder, Logical Head and Physical Sector, d[Cyl],[Hd],[Sec],[NumSecs]
Level A 'e': Rev 0018.0000, Overlay, Translate Nominal Cylinder and Logical Head, e[Cyl],[Hd],[Sec],[SysAreaOpt]
Level A 'f': Rev 0018.0000, Overlay, Translate Physical Cylinder, Logical Head and Physical Wedge, f[Cyl],[Hd],[Wdg],[NumWdgs]
Level A 'g': Rev 0001.0002, Overlay, Write Band, g[Band],[Offset],[Count],[Options]
Level A 'h': Rev 0001.0002, Overlay, Read Band, g[Band],[Offset],[Count],[Options]
Level A 'l': Rev 0016.0001, Overlay, Display Track Information, l[LogCyl],[Hd],[SysAreaOpt],[Opts],[RowsPerPage]
Level A 'q': Rev 0001.0001, Overlay, q[RWQoptions], [StartLba],[TransferLength],,[Opts]
Level A 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level C 'B': Rev 0001.0001, Overlay, Display Channel Status List Data
Level C 'D': Rev 0003.0000, Overlay, Display Channel Memory, D[MemorySelect],[StartAddress],[NumberOfSymbols],[BufferSelect]
Level C 'E': Rev 0001.0000, Overlay, Display Bonanza Memory Size, E
Level C 'G': Rev 0001.0000, Overlay, Set Channel Status List Triggers,[mask]
Level C 'H': Rev 0001.0000, Overlay, Set Channel Status List Thresholds,[action],[value]
Level C 'Q': Rev 0001.0000, Overlay, Display ASCII Command Information, Q[CmdLevel],[Cmd]
Level C 'S': Rev 0000.0000, Overlay, Display Channel Status List Status
Level C 'T': Rev 0012.0000, Overlay, Goop Plot, T[Hd],[StartTrk],[EndTrk],[ECCLvl],[NoFrcSync],[SkipCnt]
Level C 'U': Rev 0003.0001, Overlay, Display / modify media cache
Level C 'a': Rev 0001.0000, Overlay, InjectChannelADC, a
Level E 'B': Rev 0012.0001, Overlay, Write Wedge, B[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opt],[RegAddr0],...,[RegAddr13],[TSpacing]
Level E 'C': Rev 0011.0001, Overlay, Read Wedge, C[WedgeAddr],[NumWedges],[NumSkipedWedges],[TranSize],[Opts],[RegAddr0],...,[RegAddr13]
Level E 'G': Rev 0001.0000, Overlay, HeadDegradation, G[OperationControlOptions],[MeasurementControlOptions]
Level E 'n': Rev 0001.0000, Overlay, Dibit Extraction, n[sctr],[cnt],[dibit],[dibit],[dibit],[skip],[trim],[dsply]
Level E 'o': Rev 0011.0000, Overlay, Fine RW Offset Measurement, o[NumAvgs],[TrkStepSize],[NumGuardTrks]
Level E 'w': Rev 0011.0002, Overlay, Slow Write CHS, w[Sec],[NumSecs],[ConSec],[Skip],[UnitOfSkip]
Level F 'b': Rev 0011.0000, Flash, Set Baud Rate, b[BaudRate],[MsecDelay]
Level F 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level F 'C': Rev 0011.0000, Overlay, Buffer Copy, C[SrcBlk],[DestBlk],[NumBlks]
Level F 'D': Rev 0011.0001, Overlay, Memory Block Display, D[AddrHi],[AddrLo],[CompVal],[NumBytes],[Opts],[SizeInBytes]
Level F 'I': Rev 0001.0000, Overlay, IdleTaskControl, I[enable]
Level F 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level F 'R': Rev 0002.0000, Overlay, Displays BER Count, R[Head],[SingleHeadZone]
Level F 'U': Rev 0011.0000, Overlay, Spin Up Drive, U[HoldState],[Hd],[Cyl]
Level F 'V': Rev 0011.0000, Overlay, Buffer Compare, V[SrcBlk],[RefBlk],[NumBlks],[ContOnErr]
Level F 'Y': Rev 0012.0001, Overlay, Set Retries - DERP, Y[Mode],[MaxRdRetries],[MaxWrtRetries],,[Options]
Level F 'Z': Rev 0011.0000, Overlay, Spin Down Drive, Z
Level F 'g': Rev 0001.0000, Overlay, ConfigureGPIOTestPins, g[SubCmd]
Level F 'p': Rev 0002.0000, Overlay, GetSetPartitionAttributes, p[dsk sz],[sparing],[restore parms],[host blks per dsk],[PI type]
Level F 'r': Rev 0011.0001, Overlay, Read System CHS, r[LogSec],[NumSecs],[Opts]
Level F 's': Rev 0011.0000, Overlay, Seek to Physical Cylinder and Head, s[Cyl],[Hd],[ValidKey],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level F 't': Rev 0011.0000, Overlay, Write Peripheral Register - channel or preamp, t[OpType],[RegAddr],[RegValue],[RegMask],[RegPagAddr]
Level F 'y': Rev 0011.0000, Overlay, Set DERP Retry State, y[Type],[PathState],[RetryStateCnt],[LoopCnt1],[LoopCnt2]
Level F 'z': Rev 0012.0000, Overlay, SataDebug, z[SubCmd],[Parm1],[Parm2],[Parm3]
Level G 'B': Rev 0011.0000, Overlay, Fill Correction Buffer, B[StartAddr],[EndAddr],[Pattern],[Opts]
Level G 'C': Rev 0011.0000, Overlay, Copy Correction Buffer, C[SrcAddr],[DestAddr],[NumSyms]
Level G 'D': Rev 0011.0000, Overlay, Display Correction Buffer, D[StartAddr],[EndAddr],[CompareData]
Level G 'E': Rev 0001.0000, Overlay, ToggleEdacEnable, E
Level G 'F': Rev 0011.0000, Overlay, Fill Super Parity RAM, F[StartAddr],[EndAddr],[Pattern]
Level H 'B': Rev 0011.0000, Overlay, Buffer Display, B[DisplayBlk],[RefBlk],[NumBlks],[Opts],[SymBits]
Level H 'D': Rev 0001.0000, Overlay, Amplitude Ratio Sensor, D[Flags],[NumCollectionsToAvg],[Head],[FafhDiameter],[HscIntgLength],[PctOfBpi],[ChannelFreqMhz],[StartHtr],[EndHtr],[HtrIncr],[PreAmpGain],[CtffrScaler],[Ctffr],[Zfr],[PctOfTgtClr],[ChannelPreheatRevs]
Level H 'I': Rev 0001.0000, Overlay, Serial Identify, I[Strt],[Cnt]
Level H 'P': Rev 0011.0000, Overlay, Set Buffer Pattern, P[PatternSelOrPatternLow],[PatternHi],[PatternBits],[Opts],[BlkNum],[NumBlks]
Level H 'S': Rev 0011.0000, Overlay, Seek to Logical Cylinder and Head, S[Cyl],[Hd],[Offset],[OffsetUnitsOpt],[SkType],[Options]
Level H 'f': Rev 0002.0000, Overlay, DisplayModifyFafhParms, f[Options],[ParmValue],[Ix0],[Ix1],[Ix2],[Ix3],[Ix4],[Ix5],[Ix6],[Ix7],[InitParmFileEnable]
Level H 'l': Rev 0001.0000, Overlay, DisplayFafhHistoryLog, l[Options],[Interval],[Frame],[Head],[Diameter],[ClearLogEnable]
Level H 'q': Rev 0001.0000, Overlay, DisplayFafhConfig, q
Level H 't': Rev 0001.0000, Overlay, TriggerFafh, t
Level L 'C': Rev 0011.0000, Overlay, Copy Log File, C[SrcLog],[DestLog],[AppendOpt]
Level L 'D': Rev 0013.0000, Overlay, Display Log File, D[Log],[ErrCode]
Level L 'E': Rev 0011.0001, Overlay, Enable / Disable Logging, E[ErrLoggingOpt],[AsciiLoggingOpt],[RwStatsLoggingOpt]
Level L 'I': Rev 0011.0000, Overlay, Display Log FileInfo, I[Log]
Level L 'R': Rev 0001.0000, Overlay, Read SMART Log, R[LogAddr],[LengthInBytes],[Offset],[Options]
Level L 'W': Rev 0001.0000, Overlay, Write SMART Log, M[LogAddr],[LengthInBytes],[Offset],[Options],[StringValueForOptns]
Level L 'c': Rev 0011.0000, Overlay, Create Log File, c[Log],[LogType],[BufferOrDiskOpt],[NumBytes]
Level L 'd': Rev 0011.0000, Overlay, Delete Log File, d[Log]
Level L 'i': Rev 0011.0000, Overlay, Initialize Log File, i[Log]
Level M 's': Rev 0002.0000, Overlay, Serial Port Test Results, s[Sub-command],[SptIndex],[ValidKey]
Level M 'l': Rev 0001.0000, Overlay, Loopback, l
Level T 'B': Rev 0011.0000, Flash, Set Baud Rate, B[BaudRate],[MsecDelay]
Level T 'S': Rev 0001.0000, Flash, Reset drive customer settings, SHIP,[ParmValue]
Level T 'm': Rev 0017.0219, Flash, Format Partition, m[Partition],[FormatOpts],[DefectListOpts],[MaxWrRetryCnt],[MaxRdRetryCnt],[MaxEccTLevel],[MaxCertifyTrkRewrites],[ValidKey],[DataPattern],[2ndMaxWrRetryCnt],[2ndMaxRdRetryCnt][2ndMaxEccTLevel]
Level T 'E': Rev 0015.0000, Overlay, Display / Edit Log, E[LogNum],[ErrCodeOrSpecialFuncKey],[SpecialFunc]
Level T 'F': Rev 0011.0000, Overlay, Display / Modify Congen, F[ValueRef],[Data],[ResetEnable]
Level T 'J': Rev 0012.0000, Overlay, Display / Modify CAP, J[ParmValue],[ParmId],[ParmArrayBytes],[ParmByteArrayOffset]
Level T 'O': Rev 0001.0000, Overlay, Select Data Output Mode, O[Mode],[VerboseOpts]
Level T 'P': Rev 0011.0000, Overlay, Download Generic File, P[FileBytes]
Level T 'R': Rev 0012.0000, Overlay, Read Non-Volatile Adaptive Parameters, R[Opts]
Level T 'V': Rev 0029.0000, Overlay, Display Defect Lists, V[ListMask],[Hd],[StartCyl],[NumCyls],[Summary],[FlagsMask]
V1 - User Area Slip List : Rev 1.0
V2 - System Area Slip List : Rev 1.0
V4 - Reassigned Sectors List aka "Alt List" : Rev 2.0
V8 - Servo Flaws List : Rev 1.0
V10 - Primary Defect List aka "PLIST" : Rev 1.0
V20 - Primary Servo Flaws List : Rev 1.0
V40 - Nonresident G List : Rev 1.0
V80 - Resident G List : Rev 1.0
V100 - Primary DST List : Rev 1.0
V200 - Data Scrub List aka "Mickey Cert List" : Re
Level T 'W': Rev 0011.0000, Overlay, Save Adaptives To Flash, W[Seg],,22
Level T 'X': Rev 0001.0000, Overlay, Copy BIGS files to Serial Flash From Disc, Xfefe
Level T 'i': Rev 0011.0003, Overlay, Initialize Defect List, i[DefectListSelect],[SaveListOpt],[ValidKey]
Level T 'r': Rev 0001.0000, Overlay, Read File, r[FileId],[VolumeNum],[CopyNum],[ByteOffset],[Length],[OutputFmt]
Level T 'q': Rev 0001.0000, Overlay, List Physical Head Table, q
Level T 'y': Rev 0003.0002, Overlay, List SIM files, y[Volume], [FileDescriptor], [Option]
Level T '[': Rev 0011.0000, Overlay, ASCII Log Control, [[LogFunction],[Log]
F3 C>
PostPosted: March 10th, 2017, 1:43
huangmiaofang, how did you manage to unlock it?
PostPosted: March 17th, 2017, 14:15
amazing ,
he unlocked it before anyone else ,great
PostPosted: March 18th, 2017, 3:35
no, rosewoods are unlocked since about august here. Also Crawford, Makara, Lamarr, M10P...
PostPosted: March 20th, 2017, 2:38
Undoubtly, pepe (Peter) was the first to unlock signed drives. I guess the log from huangmiaofang has nothing to do with "know-how" unlocking methods.
PostPosted: April 28th, 2017, 4:07
Hello, did anyone manage to unlock it and willing to share/do it?
Users browsing this forum: No registered users and 51 guests
