 Post subject: Seagate ES.2 1TB, detected but won't read user data.
PostPosted: November 22nd, 2016, 3:29
Hello.
I have a Seagate ES.2 HDD from raid. It is initializing normally and is detected by PC-3000 UDMA, passport data is correct.
Terminal goes likes this:
(S) SATA Reset
Send Status: COMRESET seen
Set Transfer Mode selected
Ultra DMA selected
(DOS) Initializing OUGHT-TO scan session: 0x000037D6 - 0x00005437
(DOS) Scan aborted
ProcessRWError -Read- at LBA 00000840 Sense Code=40000087
Starting LBA of RW Request=00000800 Length=FFFFFFFF
ProcessRWError -Read- at LBA 00000843 Sense Code=43110081
(S) SATA Reset
Ultra DMA selected
(DOS) Initializing OUGHT-TO scan session: 0x000037DF - 0x00005437
(DOS) Scan completed
SMART reports too much reallocated sectors.
When I try to read the data with Data Extractor, I get read errors (ERR ABR) starting from LBA 0.
Data is important, HDD itself is not.
I appreciate any help, thank you.
 Post subject: Re: Seagate ES.2 1TB, detected but won't read user data.
PostPosted: November 23rd, 2016, 19:40
Probably something with translator. Are you first who is looking this drive? Did you save system modules and files? Did you see any broken?
