 Post subject: Rare Seagate PCB repair help needed
PostPosted: November 28th, 2016, 10:57
Dear friends
This Seagate hard disk is precisely 10 year old & very rare . Its pcb is shorted and when powered pc does not start.
I am not getting donor pcb so the only option is to carefully repair patient pcb.
I think one of the diode is opened .
Can someone pls. help me to diagnose pcb
Thank you
Family -- Barracuda 7200.9 ( first time I have seen 500GB hard disk (classic non F3) in this family 7200.9)
Hard disk model - ST3500841AS
FW -3.AGE
PCB rev. - 100383395 Rev. B
 Post subject: Re: Rare Seagate PCB repair help needed
PostPosted: November 28th, 2016, 11:21
Not that rare:
http://www.ebay.com/itm/Seagate-ST35006 ... 4d44964021
http://www.ebay.com/itm/PCB-Seagate-ST3 ... Swt7pXNnE4
http://www.donordrives.com/catalogsearc ... =100383395
However, given what you're describing I'd guess that the TVS diodes might be shorted. If you just need data back you can likely just remove the shorted one and copy the data out using a clean power supply. I've circled what they look like in red here:
PostPosted: November 28th, 2016, 14:25
http://www.users.on.net/~fzabkar/HDD/TVS_diode_FAQ.html
PostPosted: November 28th, 2016, 17:04
Which diode and what is the reading you are getting in both directions? Is it getting hot? Most likely can be removed.
PostPosted: November 29th, 2016, 9:07
Thank you data-medics , fzabkar & Jgan
I will test diodes by removing one by one & update result.
Thank you , I am sure this will help.
Fzabkar has written comprehensive article on diodes , very much useful , special thanks. :D
PostPosted: November 30th, 2016, 16:04
Rudra wrote:
Dear friends
Thank you
FW -3.AGE
if pcb repair its very good else contact me for working pcb (919869000986)
PostPosted: December 1st, 2016, 7:20
Dear Team
Thank You so much for all the help.
Data-medics diagnostics was precisely right. One diode which he has marked was short . I removed that diode and disk got normal detection.
100 % data from disk was recovered successfully.
Thanks again. :D
cdma-India -- I have noted your no. Pls. PM your email id and address , I will contact you for spares.
PostPosted: December 1st, 2016, 11:40
Awesome dude! It is nice when you run into those kind of situations. Makes life easier sometimes than dealing with these "problem children" for hard drives we occasionally get. :mrgreen:
Remember, take your time. Be persistent. If you have doubts stop. Check, then proceed again.
PostPosted: December 2nd, 2016, 2:27
Thanks Omega. You are right. :D
Users browsing this forum: No registered users and 68 guests
