 Post subject: WDC WD20 EACS-11BHUB0
PostPosted: November 29th, 2016, 10:00
Hi everyone, my Western Digital HDD start make strange things... form last week it slow my computer like never! it's 2Tb hdd and on task manager i can see it working constantly at 90%.. i can't do nothing... so i try to connect with usb interface and now stops to work at 90% but i can't see partition table and data.. i can only access with data RAW tools readers.... is it somethings bad on logic board? maybe the firmware? (it seems everythings is good on disks surface after long scan) can you provide a solution i wanna understand what's uppened! thank's! :)
 Post subject: Re: WDC WD20 EACS-11BHUB0
PostPosted: November 29th, 2016, 11:23
Hi! Doesn't look like firmware (or maybe slow responding error) or PCB problem. I guess it could be partition (NTFS, FAT, other?) corruption. What tools have you already used ? How much time did long scan take?
Best!
F
PostPosted: November 29th, 2016, 13:00
I used Western Digital Tool for long scan... takes about 4 days.. now i'm doinf raw copy tool.. but it's strange the file is taking more then 2tb on my good hd... and before i tru acronis true image copy and see a disk with 15Tb of capacity... i'm sure the partition it's a FAT32/NTFS with win Xp OS..
PostPosted: November 29th, 2016, 13:28
Hi!
4 days seems to be a long time for a scan. Probably you have a slow responding problem. Does the hdd show correct ID and Serial number? What do you see in windows drives manager?
Are you trying to do a image file (clone your hdd to a file) or a raw recovery (look for files in your hdd and ectract them by extension type)? If it is the second choice, could you extract some healty files? Can you upload a screen shoot of what you are doing?
As it has been said several times:
Remember DIY has its pros and cons, if data is important it is better to send drive to a DR Comapny
Best,
F
PostPosted: November 29th, 2016, 13:54
i'm doing raw copy for extract data..just for be sure! R-Studio. Need more info?
PostPosted: November 29th, 2016, 14:59
R-Studio sees your NTFS partition, what happend if you double click on it?. You are creating a image file. If your HDD is 2TB capacity you will generate a 2TB image file.
Best!
F
PostPosted: November 29th, 2016, 15:10
yes of course i decide to create the image file to secure partition and structure on my backup drive via USB external interface... but if i connect with sata directly to my motherboard i can't use it! the system process start to use all the bandwidth! (and keep it really slow) and i can't acces the drive..... i don't have a screen right now maybe i will send you later... i can't try click on it but i'm sure i can expand directories from the structure tree.
What about "Current Sector Pending Count" and "Off-Line Uncorrectable Sector Count" voices from HDD Sentinel?? Are these ok?
PostPosted: November 29th, 2016, 16:05
Molto probabilmente ci sono diversi settori danneggiati sulla superficie, di cui diversi sulla MFT, ma non c'è da escludere un eventuale problema di testine.
Potresti provare a clonare l'hdd con qualche distro linux (esempio DDRescue, WHDD, HDDSuperClone), ma ti servirà un altro hdd (vuoto) di capacità almeno pari su cui effettuare la clonazione.
Con HDDSuperTool invece potresti risolvere l'eventuale problema della ReLo list che rallenta tutto, prima però dovresti fare un backup del firmware, ad esempio con la versione demo di Sediv o di WDR (non so se sia possibile fare il backup del firmware con HDDSuperTool).
My firmware database:
PostPosted: November 29th, 2016, 16:54
ok durante la copia ho riscontrato solo un settore danneggiato, di sicuro la MFT è messa male... sto facendo la copia su immagine 2tb ma non su un altro hdd... che non ho al momento... mi sembra di capire che il rallentamento se connesso via S-ATA è dovuta alla ReLo list? è giusto? mha.. appena ho terminato la copia vedo cosa posso fare con una live... Grazie (proprio non ho capito perchè se lo collego S-ATA si blocca tutto.. lavora sta al 90% di carico.. nessuno strano rumero se non che quello delle testine che lavorano...)
ok during copy there was only one damaged sector, sure that MFT is corrupted, i'm doing a raw image but not a bit to bit copy on another hdd (cause i don't have right now)... so you Do you think that make my system slow on S-ATA connection cause of ReLo List? mha... when i complete raw image i will look what can i do with a linux live distro..Thank's (i really don't know why if i connect it with S-ATA.. everithings block and run slowly... with workload at 90%.. no noize come from hdd, only head noize normal operations... )
PostPosted: November 29th, 2016, 21:06
Done... image is created.. i'm sure now MFT is gone and Both Boot sector and Mirror Boot sector are gone too.. what can i do so? i can see on the image the $MFT and $MFTMirror files ... but is there any way to understand where is locate on the disk to start scan from there or wait for testdisk recover it ?
PostPosted: November 30th, 2016, 8:08
Non usare testdisk, fai piuttosto una scansione completa dell'immagine in R-Studio.
PostPosted: November 30th, 2016, 8:42
ok fatto! ho la copia fatta con r-studio ed è perfetta, posso ripristinare eventualmente i files... ....con testdisk ho provato senza riuscire a riscrivere la partizione ma sembra non funzionare... o meglio adesso tramite bios è funzionante ma win xp non si avvia faccio un check disk approfondito adesso con la recovery console.. dovrebbe andare, almeno spero... altrimenti LLF e installo dinuovo win xp sperando che non si ripresenti il preblema dell'uso al 90% del disco!
PostPosted: November 30th, 2016, 15:12
Ok guys chkdsk /p /r run from win recovery console solved the issue! that's it.
Users browsing this forum: No registered users and 64 guests
