 Post subject: Anyone got loader for WD5000AAVS-00ZBT0 version 5C003G
PostPosted: December 5th, 2016, 7:19
Anyone got pc3000 loader for WD5000AAVS-00ZBT0 version 5C003G ?
thank you
 Post subject: Re: Anyone got loader for WD5000AAVS-00ZBT0 version 5C003G
PostPosted: December 5th, 2016, 7:53
here you go
good luck
WDC WD5000AAVS-00ZTB0 01.01B01 WD-WCASU0253095.zip [3.47 MiB]
Downloaded 468 times
Data Recovery Pakistan
PostPosted: December 5th, 2016, 14:47
Thank you MindMergepk
PostPosted: December 6th, 2016, 5:47
Incompatible firmware, i need fw 005C003G, anyone got this fw version? Thanks
PostPosted: December 6th, 2016, 8:50
Here you go
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 4
>Cyl Count............................... : 86
>Zone allocation table................... : Ok
>SA SPT.................................. : 1280
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 5C.3GG
>ROM generation.......................... : 5C.3GG
>Link table version...................... : 01.42.
>Consolidated ROM version................ : 005C003G
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 4
>Switched off heads...................... : No
>Heads map............................... : 0,1,2,3
>ROM Firmware version.................... : 005C003G
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [157.9 KiB]
Downloaded 546 times
PostPosted: December 6th, 2016, 8:59
Thank you northwind
