 Post subject: forensic cloning of SCSI disks
PostPosted: December 7th, 2016, 12:19
Dear all friends
I want to make sector by sector clone of a72 GB SCSI hard disk. Obviously I cant do it within windows as windows may alter source /target disks.
my normal choice is DOS and dos based cloning tools. Unfortunately these tools have become obsolete and developer do not support them anymore.
Other alternate will be Linux , but I am strictly a windows guy and not much proficient using Linux.
can someone pls. suggest any alternate.
Thank you
 Post subject: Re: forensic cloning of SCSI disks
PostPosted: December 7th, 2016, 13:40
If you need these drives cloned for forensically sound copies, you are best to seek the services of someone who already knows how to do it.
Recovery Force Data Recovery
PostPosted: December 8th, 2016, 1:55
Use AccessData FTK imager!
Phoenix Computer Forensic Laboratory
http://www.databack.ir
PostPosted: December 8th, 2016, 3:15
Hi all
Thanks for the suggestions.
FTK imager is good tool ,but it can only Image ,I think it does not support cloning.
PostPosted: December 8th, 2016, 5:29
OSForensics....
PostPosted: December 8th, 2016, 7:34
You fan use SCSI write blocker to connect hdd to PC. And any software for imaging/clone.
Sistrum Data Recovery
http://www.sistrum.mk/en
PostPosted: December 9th, 2016, 2:15
hi Kum
Yes write blocker is good solution ,but scsi interface is too old and such cases come one in 1-2 years. So dead investment is not justified .
Besides you can do his job using proper softwares too.
Here I have completed task , I have used DOS based tools.
I have hdd duplicator licensed version too (last official build) ,but it is not updated in years and some mebera re skeptical for it.
I have cloned scsi to SATA first ( Redced size of 1TB target SATA to 72 GB first)
Then cloned from SATA to scsi again.
I have checked SHA1 using OS forensic of all 3 drives which is precisely same so all 3 disks are digitally identical.
thanks all for the help
PostPosted: December 10th, 2016, 7:20
I think Barts SCSITOOL may work. Not sure if it's avaliable anymore..
http://academy.delmar.edu/Courses/ITSY2 ... otDisk.htm
PostPosted: December 10th, 2016, 10:53
:D :D :D :D :D Thanks Guru :D :D :D :D
SCSITOOL will definitely help me in future cloning .
Users browsing this forum: No registered users and 31 guests
