 Post subject: st1000dl002
PostPosted: December 8th, 2016, 15:09
ST1000dl002
Barracuda LP
PN 9TT153-570
FW CC98
some times it showing in bios only
not shows in windows
I checked with terminal
heads
F3 T>/7X
Head 00 Resistance 00D7
Head 01 Resistance 0160
Head 02 Resistance 0119
 Post subject: Re: st1000dl002
PostPosted: December 8th, 2016, 22:50
Most likely taking care on sysfile 93 + hardware imaging will do
PostPosted: December 9th, 2016, 2:54
Can you explain me please?
PostPosted: December 9th, 2016, 3:02
Type "F" at level T and post the output.
PostPosted: December 9th, 2016, 8:43
Sir I attached F3 T> F level output
F.TXT [75.32 KiB]
Downloaded 1424 times
PostPosted: December 9th, 2016, 14:09
I believe that issuing the following commands (at level T) will achieve the same end as jermy is suggesting.
    F,"READ_SPARING_ENABLED",0,22
    F."WRITE_SPARING_ENABLED",0,22
    F,"OFFLINE_SPARING_ENABLED",0,22
    F,"DAR_ENABLED",0,22
    F,"DISABLE_IDLE_ACTIVITY",1,22
    F,"BGMS_DISABLE_DATA_REFRESH",1,22
    F,"ABORT_PREFETCH",1,22
    F,"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
    F,"READ_CACHING_DISABLED_ON_POWER_UP",1,22
You might like to read the following thread before proceeding.
Seagate F3 Arch - Patching the 093 sysfile :
http://www.hddoracle.com/viewtopic.php?f=59&t=1842
After making the changes, I would dump the full set of parameters again. then compare them against your first F list.
PostPosted: December 10th, 2016, 0:24
Sorry, I think that should have been ...
    F"READ_SPARING_ENABLED",0,22
    F"OFFLINE_SPARING_ENABLED",0,22
    F"DAR_ENABLED",0,22
    F"DISABLE_IDLE_ACTIVITY",1,22
    F"BGMS_DISABLE_DATA_REFRESH",1,22
    F"ABORT_PREFETCH",1,22
    F"READ_LOOKAHEAD_DISABLED_ON_POWER_UP",1,22
    F"READ_CACHING_DISABLED_ON_POWER_UP",1,22
PostPosted: December 10th, 2016, 6:49
Apparently, head 0 is not completely ok. I prefer to check it by testing sysfile 181 before any attempts to fix SA.
PostPosted: December 10th, 2016, 11:27
with what command?
PostPosted: December 10th, 2016, 15:29
I attached sysfile181
PostPosted: December 11th, 2016, 2:07
with what command?
Just RW test. What kind of tool do you use?
PostPosted: December 11th, 2016, 7:10
with what command?
I have only TTL adoptor using through hyper terminal
It's not detecting in bios too(sometimes) no detection in windows
after waiting long time
Iam getting
Rst 0x20M
(P) SATA Reset
ASCII Diag mode
F3 T>
PostPosted: December 11th, 2016, 7:30
    F"DAR_ENABLED",0,22
F3 T>F"RWRecoveryFlags",00,22
F3 T>F"BGMSFlags",00,22
F3 T>F"PerformanceFlags",043C,22
F3 T>F"MediaCacheControl",00,22
I nothing happens
PostPosted: December 11th, 2016, 17:41
Spildit wrote:
Post terminal LOG.
Are you willing to pay something for the recovery ?
hdd SENT TO U?
PostPosted: December 11th, 2016, 17:59
prasadsv wrote:
Spildit wrote:
Post terminal LOG.
hdd SENT TO U?
FOR aLL COMMANDS U MENTIONED i'M GETTING
OUTPUT
(D) SATA Reset
PostPosted: December 13th, 2016, 18:21
Spildit wrote:
And of course plug the drive to TTL on the computer that you will send Teamviewer ID.
Today I open the drive I have seen heads bended up. It has only one head on each arm
Nothing happens on platter surface
PostPosted: December 13th, 2016, 18:27
Spildit wrote:
Did you replace them ? Can you image the drive now ?
I told you .... if you were to continue you would mess up the drive for sure....
I have to find donor
Can I use heads from bad sector drives?
PostPosted: December 13th, 2016, 18:40
This is how I feel for Spildit just reading this thread:
Sadly a little information in the wrong hands is a very dangerous thing to play around with.
PostPosted: March 24th, 2017, 17:03
Spildit wrote:
If you are sure that the "Bad sectors" are not caused the inability of the head to read .... And if you are sure that the heads were not damaged by the bad sectors .....
I would start by using a proper drive that you are sure to be working fine and not some junk drives to save costs ....
But at this point your client is already screwed i guess .... Starting to think that it was a BAD idea to advice you in the first place.
If you couldn't do the recovery you should have told your client to send the drive to another place or to outsource it yourself.
It's no longer safe to proceed any further.
Finaly i got same drive and replaced heads
Got all data (5gb loss in windows partion ) easily
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 34 guests
