 Post subject: Problems : Maxtor Ardent chip & PC3000
PostPosted: February 5th, 2005, 8:06
Hi. I tried to fix my maxtor with pc3000 but it doesnt recognize it. PCB is ok. Its 160 Gb on ardent chip, does pc3000 support it ? I tried Poker (my hdd shows calypo) but no results. Is there any soft supporting ardent chip ??
 Post subject:
PostPosted: February 5th, 2005, 12:56
hi,
- sorry but i have only 14.00 and don't know Ardent chips
- only Calipso, Falcon, N40p, AREs, Vulcan, Romulus, Athena, Nike, Rigel, Proxima, uff ...
Posted 5/2/2005, 21:04:
hi,
Maxtor PC 3000 DOS 14.00 PC 3000 ver 1.0 Windows
CPU Poker, Ardent + +
CPU DSP + -
MX 740/540 + -
Maxtor 7xxx + -
Maxtor LXT + -
 Post subject:
PostPosted: February 5th, 2005, 19:38
What's wrong with your maxtor? pc3k supports this chipset, but it doesn't support drives over 137GB. it's LBA28.
I found that pc3k supports WD drives up to 200GB, so depending on the problem you have with your drive, you might be able to fix it.
Tony.
 Post subject:
PostPosted: February 8th, 2005, 7:58
This is not chip, the CHIP that "sqlab" refere here is the processor of the PCB, and this that you wrote are the ID of Maxtors ( to let it simple )
And yes yes yes, there is an ARDENT processor in MAXTORS Disk Drivers / Hard Disks / Hard Discs / Windeschesters etc.
Users browsing this forum: Google [Bot] and 263 guests
