 Post subject: WDC_WD5000AAKX-75U6AA0
PostPosted: December 27th, 2016, 15:59
The hdd responding very slow to make partition in windows or windows installation
 Post subject: Re: WDC_WD5000AAKX-75U6AA0
PostPosted: December 27th, 2016, 16:04
Probably slow responding problem. Can be solved with hddsupertool, but them you have to see if there are other problems around. You can check SMART and see what it says. Is your intention recover your data or re use your hdd?
Best!
F
PostPosted: December 27th, 2016, 16:08
Best!
F
just testing drive practice
in bios SMART enabled no error there
PostPosted: December 27th, 2016, 16:26
you can use CristalDiskInfo to check SMART parameters and see if there are some on them close to threshold.
PostPosted: December 27th, 2016, 16:56
HERE CRISTALDISK INFO
PostPosted: December 27th, 2016, 17:08
I think you have an issue with rellocated sector count. Use hddsupertool to do a slow fix (you can seacrh in this forum for procedure) and then mhdd to check sectors.
Best!
F
PostPosted: December 27th, 2016, 19:59
If you need to recover data from the drive then you should use HDDSuperTool to apply the slow fix, and then HDDSuperClone to clone/image the drive. The drive has many bad sectors, maybe even a weak head. If you wish to try to reuse it, you can follow Spildit's information, but you will never be able to trust the drive, and it will likely not last long.
http://www.hddsuperclone.com
Home of HDDSuperClone
PostPosted: December 28th, 2016, 13:59
Respectable maximus and spildit sirs,
Just I'm doing practice to keep this drive for feahtture use for data recovery by using heads and PCB
PostPosted: December 28th, 2016, 14:20
Then you should perform the slow fix using HDDSuperTool, and then do a clone using HDDSuperClone with the destination set to /dev/null. The data will not be copied anywhere as it is not needed, but this will allow the progress log to be built, and you can use HDDSCViewer to get a visual representation of the defects. This can tell you if there are just some bad areas, or if there is a weak head. If a head is weak then the heads may not be a good choice for a donor.
PostPosted: December 28th, 2016, 14:21
Sirrrrrrr,
This drive already has a good PCB ,You can test the heads with a good tool and if they are ok forget about slow fix and use heads the days you wanna use them
PostPosted: January 1st, 2017, 9:50
prasadsv, YOU HAVE ANY TOOLS IF YES I CAN HELP YOU IF NOT ONLY PRAYER :(
https://www.facebook.com/Galaxy-Data-Re ... 230196828/
PostPosted: January 1st, 2017, 13:06
Let's PRAY then .... for this nonsense to stop !!!
Sir, Spildit
I get these drives from CPU who intended to replace HDD and who do not need data, collecting these drives Just curious to what happen in those HDD to know I am posting Topics here.
I appreciate your replies
Thanking sir
PostPosted: January 2nd, 2017, 3:03
Spildit, MY DEAR FRIEND
I ALREADY PM MSG TO prasadsv,
If he asks for help from me I will help :D :D :D :D :D :D
PostPosted: January 3rd, 2017, 0:37
Very nice !!!
Please let us know if you manage to help him out !!!
Regards.
Well,
I Wanna Ask You ,He Wants To Practise So That He Can Use The Drive Like Heads , PCB Later On ,My Point Was And Is Again Why does he need to bother its already good ? . Applying slow fix and Doing The Longgggggggggg............... Longggggggg....... procedures will not make his pcb and heads better will they ?.I have said it earlier and i will say it now again ,If people are interested in doing and starting DR they should invest in tools
PostPosted: January 4th, 2017, 10:43
I KNOW MY FRIEND BUT OP JUST STARTED IN THIS FIELD SO .......
I like to help people feel better
BECAUSE
Man is man's work
:D :D :D :D :D :D :D :D :D :D :D :D
MY ENGLISH IS NOT GOOD
PostPosted: January 5th, 2017, 5:34
presently My concentration on basic Tools like hsa replacement and platter replace ment tools
and we are studying above Tools designing
Users browsing this forum: No registered users and 345 guests
