 Post subject: Hitachi 2,5 without label. How find a donor?
PostPosted: December 29th, 2016, 7:09
Just received an Hitachi 2,5 with heads problem.
Full label was removed and client can't find it.
Model and capacity is unknown.
How to find a donor? Suggestion?
PCB: 220 0A90351 01
PCB Label: 0J21947 - DA5260A - MzC430 - 0BG9
 Post subject: Re: Hitachi 2,5 without label. How find a donor?
PostPosted: December 29th, 2016, 8:21
Hi
It should be an HTS7250XXA7E630 series from PCB number.
www.datasave.ro
PostPosted: December 29th, 2016, 8:46
Indeed, it's from a HTS7250xxA7E630
PostPosted: December 29th, 2016, 10:37
Thanks for info.
Some useful trick to find a compatible head stack? (I cant compare P/N and MLC)
PostPosted: December 29th, 2016, 10:47
Make sure the client pays for each part with the understanding that it will be some trial and error because of what they did.
PostPosted: December 29th, 2016, 11:06
.....off course ;)
PostPosted: December 29th, 2016, 13:29
So no label and what? Is it a problem?
I don't see for what client should pay extra.
PostPosted: December 29th, 2016, 14:16
If you end up needing to change heads three times because you can't match all the specs you normally would from the label. I personally wouldn't charge extra labor for it, but they'd be buying all the parts I use whether they work or not.
PostPosted: December 29th, 2016, 16:03
any evidence that heads were not working when information on labels were mismatch? on this exact model.
Users browsing this forum: Google [Bot] and 296 guests
