 Post subject: HFS+ volume header and data recovery
PostPosted: December 27th, 2016, 18:05
Quick question, if the volume header is written 1024bytes from the beginning and end of a drive. Then how does a data recovery program get the folder structure back when a drive is reformatted with a hfs+ file system again?
 Post subject: Re: HFS+ volume header and data recovery
PostPosted: January 2nd, 2017, 3:16
GO WITH R- STUDIO
PostPosted: January 2nd, 2017, 3:43
R-Studio isn't able to rebuild the file/folder structure of a hfs+ formatted drive.
PostPosted: January 2nd, 2017, 6:25
Think this way, you got a BOOK without INDEX (& page numbering)
in order to sort things out, you HAVE TO READ THE FULL DAMN PAGES and SORT it somehow back
(RAW results means no page numbers = results based on FILE SIGNATURE) which ANY stupid app will find
usually you will have RAW @80% and 20% for original names/structure
PostPosted: January 2nd, 2017, 12:09
Hi ,
Someone has already explained you your question ,But try 3 different tools in the case ,You might get better results in at least 1 of it
PostPosted: January 2nd, 2017, 12:59
Looks like the catalog file mostly survived. Better to try DataRescue using Mac computer. But there is no a program that could to reconstruct original fs completely. Only by hands with according knowledge, probably.
PostPosted: January 3rd, 2017, 9:10
i disagree, the catalog is probably overwritten by the new catalog file. At least partially, but in my experience a very large area is preallocated and zero filled for the new catalog, so in many cases the only option is raw recovery.
PostPosted: January 3rd, 2017, 10:12
What Einsten said, but with another add-in. The pages may not be in the right order.
https://www.mjm.co.uk/
PostPosted: January 3rd, 2017, 15:00
At least, there is no punishment for attempt. He can be lucky, if format process has stopped before finish. I saw several times when it was possible to get good result after format. Hope the format process didn't complete.
Users browsing this forum: No registered users and 470 guests
