Post new topic Reply to topic  [ 31 posts ]  Go to page Previous  1, 2
 Post subject: Re: Remove TVS Diode on WD 4TB Black
PostPosted: January 4th, 2017, 15:51
This problem has been resolved. The middle fuse/resistor pointed out by F_ARG was indeed blown. A local electronics repair shop was able to replace it and drive is working perfectly now.
Thanks a billion to F_ARG and others who took the time to answer. These things are always stressful and it's a relief to be done with it.
I also want to say that while I have seen negative reviews of Donor Drives/Outsource Data Recovery on here, they could not have been more helpful in discussing the problem with me by phone. Had I not found someone local to make the repair, I would have sent the drives to them.
greg
PostPosted: January 4th, 2017, 16:15
Also wanted to add that I did find another new WD 4TB Black hard drive with the same PCB. However we did not have to use it as a donor board as the repair shop was able to simply replace the blown fuse.
PostPosted: January 4th, 2017, 18:02
Well done, fortunately "luck" was on your side this time, always a good thing ( and nothing wrong with that, we all wish for it :) )
You have a backup...right? | Tech Repairs on YouTube
PostPosted: August 14th, 2018, 14:55
Hey all,
sorry to resurrect this thread but I'm facing the exact same problem with the same dead fuse. (exact same drive)
In the right black circle there's a dead fuse (I tested it with a multimeter):
I have no idea if someone in my area will be able to replace something that tiny and delicate.
Is this a normal common fuse or should I ask for something specific?
Can I buy the fuse online and just look for someone with a matching solder iron? (Mine is way to thick for this) What should I look for?
Thanks!
PostPosted: August 14th, 2018, 16:27
Sometimes a fuse blows due to a problem in the plate and changing it can cause the plate to end up breaking when it is broken in another more delicate place.
I recommend that before connecting the board the insula of the disk is not going to be that occasions a more serious problems in the reading heads.
@Shasoosh, did you measure the 5V TVS diode?
PostPosted: August 14th, 2018, 16:31
@mhp666 My PSU fried my motherboard and took the harddrive with it. I'm pretty sure that's the reason the fuse is blown.
@fzabkar I've measured everything in the picture above. The right black circle fuse is the only one that's problematic. I'd like to replace it but can't identify with what fuse I need to replace it. I tried searching for that pcb schematics with no luck.
PostPosted: August 14th, 2018, 16:55
Look for a 2A smt fuse at places like Farnell, Digikey, Mouser, RS Components.
PostPosted: August 14th, 2018, 17:00
Thanks @fzabkar
Does the v matters?
https://www.ebay.com/itm/10-Pcs-Littelf ... m570.l1313 is good for example?
PostPosted: August 14th, 2018, 19:36
The voltage rating is OK. Good luck.
PostPosted: August 15th, 2018, 3:58
Thanks. Last question, should I get fast acting or slow blow?
(sorry, I'm really clueless with this)
Users browsing this forum: Bing [Bot] and 285 guests
